Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree367Likes
Old 01-17-2013, 01:23 PM
  #11941
PutAwayWet's Avatar
We will run a heat of WGT if we get 5 to show.
PutAwayWet is offline
Old 01-17-2013, 01:48 PM
  #11942
mcrcracer's Avatar
For people running the Ballistic 25.5, do you max out the timing or what do you run?
mcrcracer is offline
Old 01-17-2013, 02:07 PM
  #11943
Maybell's Avatar
My WGT is ready to go for this weekend!
Maybell is offline
Old 01-17-2013, 02:38 PM
  #11944
Trader Rating: 72 (100%+)
It depends.
I've heard that some do run max timing but only after closely monitoring their motor temp to be sure that their FDR is correct and their motor doesn't fry.
On the old layout, I ran my SS car (TC6 @ 1455 grams) with the motor at the "N" mark, a 30mm fan and FDR of 3.45:1. In this configuration, my car seems to be even on zip out of corners and even on top speed with the others, and my motor temperature is 140-ish. I haven't run my SS car on the new layout yet but I'll bet this FDR will still be in the ballpark.
Hopefully someone who's been racing SS on the new layout can comment.
waswadener is offline
Old 01-17-2013, 02:51 PM
  #11945
mcrcracer's Avatar
My FDR is 3.52 and I run a 30mm fan. I didn't mess with the timing at all yet, but it seemed my car was about the same speed on the straight as others, but not nearly zippy enough in and out of corners.
Old 01-17-2013, 03:15 PM
  #11946
cementsurfer86's Avatar
We've found that with the ballistic 25.5's, 40 degrees is about the limit. Ritchie brought that to our attention and its spot on. The motor seems to drop off after 40. Motor temps are an issue though, so check that frequently. An fdr in the 3.4's like Bill said is a great place to start with timing. As you become smoother, you can bump that up if needed.
cementsurfer86 is offline
Old 01-17-2013, 03:22 PM
  #11947
flameoutgarrett's Avatar
Originally Posted by tutankhamen
Nah, not anymore. I have Kyle to keep me "a breast" of all happenings.
I have another chassis was just looking for parts. I re-appropiated the brushless pod and servo mounts to my wgt. Assembling a mod car to have in the wings for the nights we dont run wgt.
So.. Yeah or nae lol
flameoutgarrett is offline
Old 01-17-2013, 04:57 PM
  #11948
I've been running my ballistic at 3.6 FDR with 44* timing and a burly 30mm fan. Seems good on top speed, scoots well out of the corners, and never seems to get hot.
I probably need to play with it more, but 3.4 @ 40* felt awfully flat, and my overall run pace and ability to defend against Jesse seems to be better with 3.6, because I can recover from small mistakes a bit faster.
It also depends on how well your car is handling. If you're having setup or driver issues resulting in lower corner speeds, a higher number FDR will probably work better.
-Mike
grippgoat is offline
Old 01-17-2013, 05:27 PM
  #11949
The car makes a difference as well, as does the speedo, etc.
Old 01-17-2013, 11:42 PM
  #11950
Speaking of ESC's ...
I noticed USVTA updated their rules to allow the Hobbywing Justock Club Spec ESC (it's also ROAR-approved). Then I noticed Hobbywing is having a sale. Fifty one bucks? What?!!!!! For a brand new ESC? Whaaaaaaaat?!!! Check 'em out @ http://www.falconsekido.com/
Thought I would let you know in case anybody is looking for an ESC.
Old 01-18-2013, 12:31 AM
  #11951
Before it gets out of hand I will post that ROAR has made the decision that all Trinity based D3.5 17.5 motors are not made to ROAR specifications. This will be a serious conversation for the Competition Committee. We will post more tomorrow as most of the CC are dreaming about Saturday's racing and not reading there emails!
Below is ROAR's official release on this matter,
After a great deal of consideration the ROAR Executive Committee has determined that the Trinity D3.5 motor and others based on the D3.5, do not comply with the organizationís required specifications for motors in the 17.5 stock class. The determination is based on the fact that motors being sold are built with wire thatís larger than maximum specification permitted. All of the random samples of the D3.5 based motors during the announced compliance checks tested with wire thatís larger than the maximum dimension. Rule 8.8.4.3.1 states clearly that ďThe three slotted stator must be wound with 17.5 turns of 2 strands of a maximum diameter of 20AWG or 0.813 mm per slot. A diameter of .813mm is the nominal measurement of 20AWG wire, and that it is the stated maximum wire diameter permitted. Itís on this basis that the Executive Committee made its determination.
Kody is offline
Old 01-18-2013, 12:33 AM
  #11952
PutAwayWet's Avatar
Default D3.5 Banned by ROAR
Since someone is sure to notice and post it, as of tonight:
Wonder what mine will fetch on EBay?
Old 01-18-2013, 12:35 AM
  #11953
PutAwayWet's Avatar
See, I should have called Panda first...
Old 01-18-2013, 12:40 AM
  #11954
mcrcracer's Avatar
Glad I didn't pull the trigger! I almost bought an EAM 3.5 today, settled with a Reedy instead
Old 01-18-2013, 12:57 AM
  #11955
So I can't race?
