Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree367Likes
Old 10-30-2012, 04:42 PM
  #11161
piper48
Guest
Posts: n/a
Kit set up works on the 6.1 on carpet. Only change I made was one hole higher on the inner rear camber link. Car is predictable with great turn in. Just my opinion.
Old 10-30-2012, 05:34 PM
  #11162
Logi Maker's Avatar
Trader Rating: 56 (100%+)
Originally Posted by grippgoat
Have you tried the kit setup on a TC6.1? It's not pretty on carpet.
-Mike
Would a novice driving a silver can actually know the difference? Could they tell if some shims were needed somewhere or something needs to be moved to a different hole?
Pretty sure just getting it around the track without breaking would be the focus.... just my opinion..
Logi Maker is offline
Old 10-30-2012, 05:46 PM
  #11163
cementsurfer86's Avatar
Wish I had a 6.1 as my first car when I started...... not that I would've known what to do with it. My TA02 was complicated enough....
cementsurfer86 is offline
Old 10-30-2012, 06:07 PM
  #11164
Didn't you say you also added more rear toe, as well?
A novice wouldn't know the difference, which is why I'm going to make sure his car is set up properly and easy to drive, so that he won't be unknowingly fighting something the car is doing wrong.
-Mike
grippgoat is offline
Old 10-30-2012, 06:30 PM
  #11165
-Mike
First five walls that get hit at any decent speed will tweak that fancy setup.....
Old 10-30-2012, 06:33 PM
  #11166
Default Silver can motor
I am looking for a silver can motor, anyone have a spare which they don't use it anymore and want to sell it?
I am looking for one, PM me.
fighter is offline
Old 10-30-2012, 06:37 PM
  #11167
Remote Control Hobbies in Woodinville had one in stock recently. The one I bought from them was $20.
-Mike
Old 10-30-2012, 06:39 PM
  #11168
And that's the first couple lessons in setup:
1) The car handles differently when you hit stuff.
2) All the things to check to make sure you've put it back the way it's supposed to be.
-Mike
Old 10-30-2012, 06:41 PM
  #11169
flameoutgarrett's Avatar
It already doesn't sound fun! Lol put him out there and let him bang it around, show him the fun before the frustration of this hobby
flameoutgarrett is offline
Old 10-30-2012, 06:43 PM
  #11170
+1
Fighter, I've got a couple of silvercans you can have, I'll be at the track Saturday. Stop by my pit table.
Old 10-30-2012, 07:01 PM
  #11171
Logi Maker's Avatar
Thumbs up
-Like
Old 10-30-2012, 07:55 PM
  #11172
I am already worried about banging it hard and then wondering if its me or the car ..
FourWheels is offline
Old 10-30-2012, 08:28 PM
  #11173
Magnet Top's Avatar
If you are chasing your tail because everything you try makes your car worse, make sure you check that your tires are properly super glued.
Attached Thumbnails Seattle RC Racers/Hangar 30-img_1500.jpg
Magnet Top is offline
Old 10-30-2012, 08:51 PM
  #11174
It's best to hit something and take off like nothing happened, u will dial yourself out of the race if you do that, hit something and continue to drive it like you stole it!
All you have to do is be repetitive, every run do the same things to your car, clean the tires the same, sauce the same, make sure everything is smooth and you will be good to go! Fun fun fun is key to sticking with this hobby
Old 10-30-2012, 08:52 PM
  #11175
Looks like they were "Properly" glued. You just drove so hard you tore the rubber right off the wheel!
Yes always check tires after every run. If you are running mod or roll a few times or your car meets the boards they will always need to be checked.
Kody is offline
