Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree369Likes
Old 10-29-2012, 06:25 PM
  #11146
Originally Posted by PutAwayWet
Through the end of 2012, we will be bumping our setup and race time up an hour.
4pm Setup
5pm Practice
6pm Q1
That's great home by 2:00?
THE WIGGLER is offline
Old 10-29-2012, 06:43 PM
  #11147
RcHammer's Avatar
Default 12th scale 5.1 inline
anyone know if im going to have to mod my novak smart boost to run stock 12th? tryin to get a second car rdy to run and really dont wanna buy another speed control
Erik
RcHammer is offline
Old 10-29-2012, 09:56 PM
  #11148
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Eric, I am going to say "no". Novak Smart Boost seem to always preform fine in non-ramping classes. It was when ramping was introduced that they would start to brown out.
Slapmaster6000 is offline
Old 10-29-2012, 09:59 PM
  #11149
Originally Posted by arn671
Wondering what rollout people are running for 12th stock with a Revtech? Are people using specific rotors or just the stock one?
Wes should be able to chime in on that if he looks at rctech. I used a Reedy last race timed at 38* rolled at 106mm with a 956 rotor.
Brian
Old 10-29-2012, 10:00 PM
  #11150
arn671's Avatar
Trader Rating: 17 (100%+)
Default 12th ???
Set up I had before was for 13.5:
arn671 is offline
Old 10-29-2012, 11:24 PM
  #11151
flameoutgarrett's Avatar
Lets see if I can help, 76 spur with a 56 pinion, 1.67 tire, I will let you do the math, it was good.. Wes was running the same I think, I was running revtech
flameoutgarrett is offline
Old 10-30-2012, 12:02 AM
  #11152
Suspended
97.6mm, timing the second from last hash mark, though cranked works okay just fades faster. I am running the black and purple rotor, a really strong one. If you fade, take a touch of timing out at a time until it improves. They are fickle.
A D3.5 with 102mm roll out and 18 degrees of timing is a very good motor as well.
Wes Briscoe is offline
Old 10-30-2012, 12:38 AM
  #11153
jaredstandiford's Avatar
i know its pretty early in the week but sean i need some double sided tape and 3mm turnbuckle wrench and how much will cost?? thanks
jaredstandiford is offline
Old 10-30-2012, 08:53 AM
  #11154
Maybell's Avatar
I'm not at work today so I will reply with a price on Wednesday.
Maybell is offline
Old 10-30-2012, 12:08 PM
  #11155
What's a good baseline setup for the TC6.1 for Stock Touring? Smooth and easy to drive is more important than outright speed. It'll be a base setup for a novice, running a silver can.
-Mike
grippgoat is offline
Old 10-30-2012, 01:42 PM
  #11156
PutAwayWet's Avatar
I think we get in the habit of immediately looking past the kit setup. The TC6.1 is an evolved version of a known good car. Start with what the manual says and take it from there.
PutAwayWet is offline
Old 10-30-2012, 02:27 PM
  #11157
Have you tried the kit setup on a TC6.1? It's not pretty on carpet.
-Mike
Old 10-30-2012, 02:55 PM
  #11158
I'm sure one of these should work. I see Kody's setup listed, copy his nats setup.
http://www.teamassociated.com/setupsheets/TC6.1/
malkiy is offline
Old 10-30-2012, 03:06 PM
  #11159
Kody's might be a bit tough to drive. I'll take a look, though.
Alvin, this is the car you sold Bhargav(sp?). Do you know what pistons and bladders are in the shocks?
-Mike
Old 10-30-2012, 03:37 PM
  #11160
cementsurfer86's Avatar
Phil runs Kody's setup, and it's butter. Easy to drive, and with the reduced speeds of novice, shouldn't be an issue, but as Todd already said, I think the kit setup would be more than adequate for novice speed.
cementsurfer86 is offline
