Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree369Likes
Old 10-24-2012, 08:26 PM
  #11131
exhAustin's Avatar
Originally Posted by jeff jenkins
For what type of radio???
I'm pretty sure it's a JR xr3i
exhAustin is offline
Old 10-24-2012, 09:55 PM
  #11132
oldrcr's Avatar
Trader Rating: 46 (100%+)
pretty sure I have one. I'll look tomorrow if I get a chance.
-Alex
oldrcr is offline
Old 10-25-2012, 03:12 PM
  #11133
Suspended
Exclamation
I am building a WGT so for those keeping count there will be +1 for the next club race if they show. I will keep it with me race ready from here on out.
Those new to 1/12 link cars, if you want help with setting up and tweaking the car come see me, or if you simply want someone to tweak the car, come see me. If you want someone to drive it and see if it needs improvement I am willing to help. Not claiming to be the authority on 1/12, but mine work.
I also posted Brian's pan car clinic, and have added my own instructions to my website, rcpitwhores.com.
Tires, for Jaco run them 40/42 or 41/43mm front/rear for fastest laps, black/yellow compound, radius the sidewalls, sauce the entire tire at least 16 minutes prior to your heat and put them on the track dry. You can sauce longer without ill effect. You can start your tires at 42/44 but they will be a little grabby now that grip is up. ...for stock this is a dialed setup and will go 8 minutes no problem.
Make sure you're ride height is square front/rear. 3.75mm vs 4mm is a big difference. Make sure you're 3.5-4mm. I start at 4 and let the car wear down until it's not acceptable. Setup your car and tires to start at 4mm and you should never really have to adjust your ride height but rarely.
Do this then setup your chassis so its balanced left/right and adjust your steering so the car turns equally left/right (do circles in the carpet) and you should have a race car.
Wes Briscoe is offline
Old 10-25-2012, 06:22 PM
  #11134
chevtech23's Avatar
Thank you Wes, Brian, and everybody else for the info. Ill be heading inro the next race with a lot more confidence now
chevtech23 is offline
Old 10-25-2012, 08:58 PM
  #11135
oldrcr's Avatar
Hmm, not where I thought it was. One more place to look.
-Alex
oldrcr is offline
Old 10-26-2012, 11:59 AM
  #11136
skypilot's Avatar
Trader Rating: 14 (100%+)
Not going to make it TZ this weekend.
skypilot is offline
Old 10-27-2012, 02:25 PM
  #11137
jaredstandiford's Avatar
getting diff oil tomorow will forsurelly be there saterday enless the world ends haha
jaredstandiford is offline
Old 10-27-2012, 02:31 PM
  #11138
chevtech23's Avatar
I picked up a used RC10R5 for WGT and I have some questions:
Whats a good starting point for setup?
Whats the target rollout for 13.5?
Whats a good size to run the tires? Saucing? Ride Heights, etc?
I noticed this car has rear ride height adjuster inserts that seem offset to make the wheelbase longer, is this a standard part or do you run the standard 1/12 scale inserts?
Thanks in advance. It looks like the touring car will be parked till pavement season lol
Old 10-27-2012, 02:55 PM
  #11139
Logi Maker's Avatar
Trader Rating: 56 (100%+)
Grant ran the Blackstock set up and liked it. I think I am at 30 side, 30/blue center, gold sides, .20 fronts. Same inserts as 1/12, 4mm min ride height, tires 52 f/r (you don't have 2mm split), rollout 85-90.. something like that..
Logi Maker is offline
Old 10-28-2012, 12:29 PM
  #11140
PutAwayWet's Avatar
Default Schedule Update
Through the end of 2012, we will be bumping our setup and race time up an hour.
4pm Setup
5pm Practice
6pm Q1
PutAwayWet is offline
Old 10-28-2012, 06:29 PM
  #11141
car is runnimg smoothly super pumped!!!
Old 10-28-2012, 09:43 PM
  #11142
Default Wanted : Tekin RS
Hello Hangar 30 Racers,
I am planning to pursue RC as a hobby and currently i am looking for a used Tekin RS ESC which would work with TC6.1.
i have tried racing a couple of times using a loaner at our Hangar, Seattle a few weeks ago, I am hoping someone has a spare for sale.
Thanks,
Pinkesh
fighter is offline
Old 10-29-2012, 12:49 AM
  #11143
arn671's Avatar
Trader Rating: 17 (100%+)
Default 12th stock ??
Wondering what rollout people are running for 12th stock with a Revtech? Are people using specific rotors or just the stock one?
arn671 is offline
Old 10-29-2012, 05:52 AM
  #11144
Trader Rating: 84 (100%+)
Just thought I would let everyone know that Spec-R just released a sport version of the R1 called the S1 and its only $118!!! WOW
jeff jenkins is offline
Old 10-29-2012, 06:18 AM
  #11145
http://www.redrc.net/2012/10/spec-r-...it/#more-59568
