Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree369Likes
Old 09-10-2012, 11:47 PM
  #10591
Originally Posted by cementsurfer86
I vote spool. The car just felt odd with a diff up front, but god did it turn.
Gear diff or ball diff? What oil? Last year I ran a gear diff with 500k Traxxas oil. I could feel it diff out and lose accelleration on exit in 17.5, but I never felt that in scale spec. The gear diff definitely felt better on entry and mid corner in 17.5, but the spool was faster. I never got a chance to try the spool in SS, though.
-Mike
grippgoat is offline
Old 09-11-2012, 08:07 AM
  #10592
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
I perfer the gear diff for Stock Spec.
OVA is offline
Old 09-11-2012, 08:49 AM
  #10593
bradshawkyle's Avatar
Originally Posted by grippgoat
Scale Spec: gear diff or spool in front? Discuss!
-Mike
I've had solid results with a ball diff and slipper pads, of course not as stout as a spool but then again I also haven't busted anything up front after a big hit, either.
bradshawkyle is offline
Old 09-11-2012, 09:01 AM
  #10594
PutAwayWet's Avatar
A request from your friendly RD...
Along with a new venue, we have a new race computer for this season. In an effort to see this Saturday go as smoothly as possible, I would like to load names, classes, frequencies, and ptx #'s in ahead of time. So, if you please, and if and as you are able, forward those to me via PM or email to [email protected]
Grazie!
PutAwayWet is offline
Old 09-11-2012, 03:13 PM
  #10595
Have a few questions regarding 1/12 scale. I'm planning on buying the new CRC car.
What tires work best with the CRC cars? Also what other items should I purchase with the car? Springs? Spacers? Anything else? I do plan to buy the slapmaster thrust bearing. .
malkiy is offline
Old 09-11-2012, 03:30 PM
  #10596
Logi Maker's Avatar
Trader Rating: 56 (100%+)
A 12R5.2 will be all you need with that..
Stock last year ran BLK FR and YEL R, pretty sure the .25 axle height spacer kit..
Not even sure that helps or if I have a clue..
Logi Maker is offline
Old 09-11-2012, 04:24 PM
  #10597
Trader Rating: 72 (100%+)
-Mike
Tried a gear diff in the front of my Scale Spec TC6 last year. The car sort of would turn in nice but was mildly pushy in the middle and especially pig-like on the way out of corners. This with either thick or thin oil in the diff; didn't seem to matter. Could probably have tuned out the bad turning characteristics if I knew more about tuning but ...
I put my beloved slipper spool back in and, like magic, the car turned in nice, stuck in the middle and stuck on the way out of corners.
Cast my vote for The Spool.
waswadener is offline
Old 09-11-2012, 04:37 PM
  #10598
Default Another tub request
Hey Sean, any chance you might have some 48p spur gears you could toss in the tub? I'm looking for 64 and/or 66 tooth specifically.
Muchas grassy-ass.
Old 09-11-2012, 05:29 PM
  #10599
How thick did you go on the oil? Did the bad turning characteristics correspond with throttle application? How much droop did you run in the front (a little or a lot)?
Franko, what weight oil did you run?
-Mike
Old 09-11-2012, 06:23 PM
  #10600
MAD916's Avatar
Hey Mike Glad to see you get a 12th scale... the new CRC car will not require the rear ride height spacers. they have a new rear pod with adj rear ride height. Front shim kit's for ride height, axle shims, rear axel shims, side spring kit, and damper tube lube is about all you would need. the new car should be dialed.
MAD916 is offline
Old 09-11-2012, 06:56 PM
  #10601
OVA
OVA's Avatar
-Mike
1000 for the rear and 600000 front
OVA is offline
Old 09-11-2012, 07:17 PM
  #10602
The thick stuff I used was from a tube of silicone oil I've had laying around the garage from who knows how long ago. Much thicker than the thickest shock oil; not quite as thick as CRC tube lube.
On or off throttle, sort of would turn mid-corner didn't want to turn much at all coming out of the corner. Was especially bad on throttle.
Car was set up with about 3mm of droop front and rear.
Old 09-11-2012, 07:47 PM
  #10603
OVA
OVA's Avatar
Last year I ran the double gear diff with 1000wt. on silver can motor. you have to be smooth coming out the corner...other wise is will push out
OVA is offline
Old 09-11-2012, 08:23 PM
  #10604
Rdog's Avatar
Trader Rating: 83 (100%+)
That new CRC car looks killer!!! Dare I make a return to the hanger?
Rdog is offline
Old 09-11-2012, 08:37 PM
  #10605
Logi Maker's Avatar
This one?
http://www.stormerhobbies.com/cgi-bi...=ns&pn=CRC3210
