Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree367Likes
Old 04-10-2012, 04:07 PM
  #10111
Maybell's Avatar
Originally Posted by waswadener
Does anybody know if the LRP x12 17.5t motor has an onboard temperature sensor, whose output feeds out through the sensor cable?
Wondering because I acquired an ESC that has the capability of reading motor temperature via the sensor cable but only with motors that have a temperature sensor. I know Novak Ballistic motors have a built in temperature sensor but I'm not sure about the LRP x12 17.5t motor.
Bill S.
Email sent to AE headquarters. Stay tuned!
Maybell is offline
Old 04-10-2012, 04:25 PM
  #10112
Originally Posted by grippgoat
For what car?
I've got some 3-Racing Spurs that do NOT fit a TC6. I don't actually know what they fit. Anyone who can use them is free to have them. I'll bring 'em with me.
-Mike
It is for a Tamiya 415, but they should all be the same, I will see you Wed. Thanks
Rob
mustangswan is offline
Old 04-10-2012, 04:27 PM
  #10113
Originally Posted by Maybell
We have 96 tooth Kimbroughs and 93 tooth Robinsons...I will bring both!
I will take 1 of each.
Old 04-10-2012, 05:47 PM
  #10114
Maybell's Avatar
Bill S.
Yes, the X-12's have a temp sensor.
Maybell is offline
Old 04-10-2012, 05:50 PM
  #10115
jaredstandiford's Avatar
hey sean do you have any pulleys that fit a 3racing spool diff for a ta05 ? i got my part in the mail and failed to notice the pulley i have doesnt work your supposed to be able to screw four screws into the pulley jsut courioes if you had one?
jaredstandiford is offline
Old 04-10-2012, 06:53 PM
  #10116
Maybell's Avatar
I have no idea, sorry.
Maybell is offline
Old 04-10-2012, 09:22 PM
  #10117
Trader Rating: 72 (100%+)
Thank you for looking into it and confirming, Sean. Much appreciated.
Bill S.
waswadener is offline
Old 04-10-2012, 10:07 PM
  #10118
bradshawkyle's Avatar
Default Screws
Guys,
I'm about to set-up my drill press to drill out the fourth hex screw in as many weeks from my TC5. I started with the black ones that came with the kit, then "upgraded" to fancy blue ones that seem softer than the originals. I have a decent Integy tool set which doesn't appear to be rounding out the insides - my best guess is these screws are just too soft to use with loctite.
Does anyone have a suggestion on where to buy reasonably priced (nothing made out of unobtanium, please) screws? Or is the "reasonable price" qualifier the reason I'm in this predicament. Any sage like wisdom would be MUCH appreciated.
bradshawkyle is offline
Old 04-10-2012, 10:15 PM
  #10119
flameoutgarrett's Avatar
Originally Posted by bradshawkyle
Guys,
Ur using locktite on your wheel screws? Only people I remember ever doing that was the guys that got them for free and only at big races, other than that aluminum is a natural loctite, way to soft for it
flameoutgarrett is offline
Old 04-10-2012, 10:17 PM
  #10120
bshookup's Avatar
Trader Rating: 21 (100%+)
Guys,
I have also ran into problems of stuck screws in aluminum bulkheads. I solved the problem by using no loctite or just smallest of drops on only a few choise screws. Instead I check my screws every other run or so and usually the only loose screw is the one behind the wheel and no amount of loctite will fix that.
bshookup is offline
Old 04-11-2012, 02:19 AM
  #10121
No, sorry, I think I mis-spoke when I said hex screw. The problem I'm running into is with the Allen (I've heard some people call them hex) screws that are all over the chassis, specifically the recessed ones going into aluminum bulkheads.
Originally Posted by bshookup
Usually the only loose screw is the one behind the wheel and no amount of loctite will fix that.
Nice...I know exactly how to fix the loose screw behind the wheel: 3-4oz Maker's Mark, 2 ice cubes, repeat as necessary.
Old 04-11-2012, 06:31 AM
  #10122
Logi Maker's Avatar
Trader Rating: 56 (100%+)
Guys,
Www.hexcrews.com. Get the Armour Plated ones....
Logi Maker is offline
Old 04-11-2012, 07:47 AM
  #10123
Rdog's Avatar
Trader Rating: 83 (100%+)
I need a good starting fdr for scale spec 25.5 motor thanks guy
Rdog is offline
Old 04-11-2012, 09:12 AM
  #10124
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
I'm at 3.9FDR some are 3.5 -4.00 FDR
OVA is offline
Old 04-11-2012, 09:15 AM
  #10125
Default Tub Request
Sean,
It it's not too late, I'd live you to throw in some battery tape (Hudy if you got it) and body clips into the tub. I could use a couple packages of clips.
Thanks,
-Kyle
