Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree374Likes
Old 02-22-2012, 01:18 PM
  #9646
Maybell's Avatar
Originally Posted by grippgoat
TC6 rod ends
TC6.1 caster blocks if you have em
Blue bulkead shims x2
Blue 3mm ballstud spacers probably x2
Can of whoop ass
-Mike
Gotcha covered!
Originally Posted by corallyman
SeanO,
Can you bring a pack of Xray 3mm X 5mm Flat head screws and a pack of AE screws with the same deminsions. Not sure which I want but I will know when I see them. I perfer 5mm length but 6mm will work too.
Steve
Gotcha covered!
The TC6/.1 kit 3x5mm flat heads are crap. The wrench doesn't seat fully in the socket, and the metal seems soft, so they're super easy to strip. I don't know if the replacement ones will be as bad.
-Mike
What tools do you use?
Originally Posted by DIALED
...If it's not too late for 'tub requests' Sean, could you toss in a set of spec tires for me? ThankS
Gotcha covered!
Maybell is offline
Old 02-22-2012, 02:08 PM
  #9647
oXYnary's Avatar
Sean, don't know if this is the same version of the servo saver from xray you already have on order for 2 others. But can I order one of these? If you have the price in your system already, I can pre-pay you tonight.
Composite Servo Saver - X-Stiff - Set 372503
(and of that Micro brushless truck happens to show up today, please throw in tub as well)
oXYnary is offline
Old 02-22-2012, 02:09 PM
  #9648
EDS, although I built the kit initially with the kit allen wrench. I'm not the only person who's complained about those 3x5's either, it's a pretty common complaint in the TC6 thread. Also, it's only the 3x5's that suck. All the other screws have been fine.
I actually replaced all my 3x5's with 3x6's from Ace hardware store. Except for the two in the top deck above the layshaft bulkheads, where there isn't room for a 3x6. I think I bought 26 screws and used 'em all, but I had already replaced a couple, so it's probably closer to 30 screws for the whole car.
-Mike
grippgoat is offline
Old 02-22-2012, 02:20 PM
  #9649
cementsurfer86's Avatar
Default Tub!
Hey Sean,
If you have a 78t spur, could you throw one in the tub?
thanks!!!!
cementsurfer86 is offline
Old 02-22-2012, 02:50 PM
  #9650
Trader Rating: 21 (100%+)
Is this for 1/12th? Why not just use a Kimbrough Med. servo saver? They center much better and Sean almost always has them in stock.
peter_robinson is offline
Old 02-22-2012, 02:54 PM
  #9651
oXYnary's Avatar
Per the centering, I think this new version above is supposed to fix it. Because yes, my stock servo saver does have play. Which makes it a PITA to attempt to get toe in/out.
Per Kimbrough, mostly worried about a different ackerman offset. If Sean sees this and has one, go ahead and bring (one with compatible JR servo spline) and I will attempt to compare holes and offset through packaging.
oXYnary is offline
Old 02-22-2012, 02:59 PM
  #9652
Maybell's Avatar
Yep, thats the one...Im not sure when we will get them, and your way down the waiting list...I hate to say it but you might want to order it online because I have no idea when they will come.
Maybell is offline
Old 02-22-2012, 03:06 PM
  #9653
oldrcr's Avatar
Trader Rating: 46 (100%+)
Default tub
Hey Sean, Tire CA for me, although I think you already bring some normally.
Thanx,
Alex
oldrcr is offline
Old 02-22-2012, 04:40 PM
  #9654
I should have a medium Kimbrough that's already opened you can do what you want with. I think I only have the futaba spline for it, though.
-Mike
Old 02-22-2012, 04:48 PM
  #9655
Maybell's Avatar
We are out of kimbrough mediums servo savers.
Maybell is offline
  #9656
Maybell's Avatar
-Mike
Gotcha
Maybell is offline
Old 02-22-2012, 11:07 PM
  #9657
gwhiz's Avatar
I've been actively watching Nexus Racing, Amain, Stormer, and Speedtech RC for stock on the 372503. Of those four sellers I have seen zero in stock for quite a while.
I am dying to try this out because I really like the quality of the plastic and tolerances on the original xray 3-spring item (372502), but I am admitting that it didn't center perfectly. I assembled my 372502 with some silicone grease and that seemed to help slightly. I just smeared it all over everything, pressed it all together, and wiped off the excess before buttoning it down. Seems to be a little better now.
Just out of curiosity, Drew: Whats the deal with the original (smaller?) X11 servo saver (372501)? Have you tried that? Is it crap?
Oh, I just checked the Hong Kong Holy RC Trinity (Mart/Market/Mushroom) and none of them show stock either, although RC Market claims it will be back in approx. 2 weeks. Fuggn Jabroni's.
gwhiz is offline
Old 02-22-2012, 11:28 PM
  #9658
gwhiz's Avatar
-Mike
Mike, just FYI, I have had great results with the Amain house brand, Protek RC. The claim is 174 ksi ultimate tensile strength, which is a very respectable figure. The thread form and head shape is very consistent, and the price is right. BTW they bear the same 12.9 grade marking you find on the kit Serpent fasteners which are quite durable.
I think it goes without saying that Xray fasteners are fantastic.
gwhiz is offline
Old 02-23-2012, 12:02 AM
  #9659
Funny you should mention that. I just got a heaping helping of ProTek 3x5mm flatheads in the mail today. I also got some 3x14 cap screws for the pivot block mounts.
-Mike
Old 02-23-2012, 01:03 AM
  #9660
oXYnary's Avatar
Yes, thats why they put the newer saver in the new x12 kit (which Im not getting now because of a looong story outside of my control).
It has play at least 2 degrees per side. In fact Tracy thought it might have been contributing to the sudden turn in exiting the corner.
I borrowed gripgoats futuba just to check the dimensions (I have JR so wouldn't work). It will change my ackerman, but ehh. Who knows, maybe its what the car needs outside a better driver.
Does anyone know if D lock diff rings for pancar axles are a generic size? Or each is particular to the axle brand?
oXYnary is offline
