Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree374Likes
Old 11-08-2011, 07:22 PM
  #7921
Maybell's Avatar
Originally Posted by GreenSC10
A true sales man Ill take three....
Seriously, Im not the best one to explain the difference....Jake?
Maybell is offline
Old 11-08-2011, 07:37 PM
  #7922
flameoutgarrett's Avatar
A gear diff will last for freekin ever.. That's the only plus I can think of.. It will be consistent tho from run to run, but te warmer the oil gets the more your car will diff out
flameoutgarrett is offline
Old 11-08-2011, 08:06 PM
  #7923
More steering and more forward bite when one is used in the rear. Very low maintenance too.
Running one in the front with putty will make the car easer to drive then running a spool.
Kody is offline
Old 11-08-2011, 08:11 PM
  #7924
Samwise's Avatar
I already have mine on pre-order from SpeedTech, but thanks!
Originally Posted by arn671
Mike, Sam, Bill(Jubilee), Jake and anyone else...
Nexus has a few kits in stock!
http://www.nexusracing.com/product_i...fd657c84d5b3aa
last count was 5 kits.
Samwise is offline
Old 11-08-2011, 08:16 PM
  #7925
Samwise's Avatar
Default Jaco Blue?
Hi,
I noticed that the spec tire for the sedan classes is the "Jaco Blue"? Is this a foam tire? Do we get to race foam sedan classes like we did in the good 'ol days? Back at Rain City, we had a few expert foam sedan guys. I think Travis would approve!
Peace,
Sam
Originally Posted by Blake
Hi H30ers,
Thank you to Brian for posting up some preliminary info for the Victoria trophy race. Brian is one of our biggest fans and has travelled up our way 3x in the last 16 months!
I have attached a PDF version of the race flyer incase it's easier to print than the JPG version above. To avoid spamming the H30 thread, I will create a separate thread in the Northwest Forum in the next couple of days.
Obviously cross border racing presents a small wrinkle (Passport or Enhanced Drivers License) but I think you'll find that it's worth it. We had 120 entries at our event last winter with 40 alone in 12th Scale.
This year we have a new 8000 square foot facility (heated) in Sidney BC, less than five minutes from the BC and WA ferry terminals. The hotel is literally across the street from the track, and there are many restaurants/fast-food within a block or two.
Blake
Samwise is offline
Old 11-08-2011, 08:18 PM
  #7926
Rdog's Avatar
Trader Rating: 83 (100%+)
No they are a rubber sedan tire I think they are close to a 32
Originally Posted by Samwise
Hi,
Peace,
Sam
Rdog is offline
Old 11-08-2011, 08:21 PM
  #7927
GreenSC10's Avatar
For my style of driving forward bite would be sweet and I'm sure there is a way to calm down the steering, because to much steering for me isn't the best. What do you mean "easier to drive" with the gear diff in the front?
GreenSC10 is offline
Old 11-08-2011, 08:22 PM
  #7928
Hi,
Peace,
Sam
Hi Sam,
No, the Jaco Blue is a rubber tire. They look like this:
http://www.rctech.net/forum/attachme...s-img_1763.jpg
This is a common spec tire for carpet races, and was the spec tire at the IIC race in Las Vegas this year. As per the WCICS series rules, you must purchase them at the event, for $30.
I hope that helps!
Blake
Blake is offline
Old 11-08-2011, 08:25 PM
  #7929
Trader Rating: 37 (100%+)
Thanks Alvin! I decided to go 1/12 though.
jubilee is offline
Old 11-08-2011, 10:56 PM
  #7930
Magnet Top's Avatar
Kody already answered but I'll give my two cents....
I suppose the biggest benefit of a gear diff is the reduction in maintenance compared to a ball diff. I used to rebuild my ball diff a lot, almost every race when we were running open esc in stock... so it was in good shape ( consistent !!! ) at all times. In mod it is a requirement to rebuild a ball diff every race unless you never get sideways on power ( not me ! ). A gear diff in stock lasts forever and doesn't change unless the fluid leaks out. One advantage of the gear diff is that you can try different weight oils for different characteristics coming into and leaving a corner. I honestly cannot give much first hand advice about different weight gear fluid because we have so little practice time which makes it difficult to do back to back testing when there are so many other adjustments to test ~ roll center, camber, camber gain, shock oils, springs, bodies, front toe, rear outboard toe, track width, narrow and wide hexes, diff position , weight bias, rake , radio settings, gearing, motor timing, sway bars, saucing techniques ..... etc etc oh yeah... and droop !
I like gear diffs !
Magnet Top is offline
Old 11-08-2011, 11:09 PM
  #7931
Logi Maker's Avatar
Trader Rating: 56 (100%+)
I like gear diffs !
Crap that is a lot of stuff to worry about.... I only have time to fix stuff!!!
WE NEED A PERMANENT TRACK AROUND HERE!!!!!!!
Logi Maker is offline
Old 11-09-2011, 01:58 AM
  #7932
Samwise's Avatar
Thanks Blake!
I didn't know Jaco made a rubber tire, that's cool. I've been out of racing for several years and just started racing again this summer. We used to use Take-Off's as a spec tire a lot the last time I ran a sedan; this was back in 2005 or so.
I look forward to this race and hope I can make it!
Peace,
Sam
Hi Sam,
I hope that helps!
Blake
Samwise is offline
Old 11-09-2011, 07:20 AM
  #7933
omega655's Avatar
Default need some more practice!
Hey all,
Just getting into on-road cars (been driving a Slash for the last couple years), and I have a VTA rig that I'd like to start racing. I see that Wednesdays are club race days, and I saw a flyer that HPI is running a Series on Saturdays. Are there practice times available during the week? I need to learn to drive this thing before I get involved in any organized racing!
PM me, or post inline if you have some info. Thanks in advance!
-dd
omega655 is offline
Old 11-09-2011, 07:30 AM
  #7934
Peeler's Avatar
PRECISELY!!!
Peeler is offline
Old 11-09-2011, 08:24 AM
  #7935
Logi Maker's Avatar
Originally Posted by omega655
Hey all,
-dd
check out the rules and schedule at www.seattlercracers.com
nowhere to practice since we DON'T HAVE A PERMANENT TRACK ANYWHERE!!!
