Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree367Likes
Old 03-06-2011, 10:12 PM
  #6511
Trader Rating: 84 (100%+)
pm sent.
jeff jenkins is offline
Old 03-07-2011, 10:15 AM
  #6512
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Hey guys, just an update on some bearing requests. Some have asked for 5x9x3 for some popular hub bearings. I have some coming in the half rubber/steel shields. I am hopeful they will be here in time for trackside support this Friday for our practice day.
Long range weather is looking warmer for the weekend. We shouldn't have to kick the penguins out this time around.
Slapmaster6000 is offline
Old 03-07-2011, 10:48 AM
  #6513
Suspended
Are you going to be stocking diff balls by themselves? I am going go order from boca today and am contemplating if I should also order balls. Thinking 3mm and 1/8".
Wes Briscoe is offline
Old 03-07-2011, 12:15 PM
  #6514
Wes, I will put that in the suggestion box. I do not stock diff balls at this time.
Old 03-07-2011, 01:10 PM
  #6515
Suspended
I ordered some to stock at the store, I'm getting in 1/8 and 3mm ceramics, the finest money can buy. I think it's going to be $3.95 for 5 balls.
Old 03-07-2011, 04:41 PM
  #6516
Default Parts are left
Still have parts for sale
File Type: pdf
wskent51 is offline
Old 03-07-2011, 05:42 PM
  #6517
RC Hobbies or Hobby Town Everett: you guys have any rattle bomb can white? Either Tamiya or Pactra?
Old 03-07-2011, 07:10 PM
  #6518
Maybell's Avatar
We have Pactra and I just threw a can in the tub in case you need it...plenty on the shelf as well...
Maybell is offline
Old 03-07-2011, 07:58 PM
  #6519
Trader Rating: 21 (100%+)
Cool Hard day at the office
peter_robinson is offline
Old 03-07-2011, 08:51 PM
  #6520
GreenSC10's Avatar
How much for 6x10? Do you carry them?
GreenSC10 is offline
Old 03-07-2011, 10:08 PM
  #6521
Looking good Pete. Can you make a mean toasted cheese in that thing too? Can't go wrong with black T's.
No 6x10 at this time. Yours is the first request.
Old 03-08-2011, 08:38 AM
  #6522
Peeler's Avatar
Hell yeah pistol pete's panini's in the near future? dang say that 5 times fast!
The shirts are rad pete keep up the good work my man! Dude when is the golf line coming out?
Ritchie- an no you cant have one your not in our panini club damn will power ran out an had to poke. Keep up the entertainment
Peeler is offline
Old 03-08-2011, 08:40 AM
  #6523
Peeler's Avatar
I need a weekend with charlie sheen after reading all the guff about our great CLUB!
Peeler is offline
Old 03-08-2011, 09:37 AM
  #6524
TracySlatten's Avatar
Hi Folks,
Putting out a call for a CRC rear lower pod plate. I believe mine is broke. If anyone has a spare pod plate they could bring to the Hangar, that would be great. I have one on overnight order but it might not make it.
Symptom: the pod snaps from side to side, with side links and pivot assembly alone. It sticks/snaps when i move the rear plate side to side through the center/flat position. I have replaced the links/balls/screws and still it seems in bind. The center pivot ball seems free and centered. The only thing i can think of is that the rear pod is broke or bent, moving the side link holes out of alignment and causing a bind. ??? (Maybell must have nerfed me into a board that last race.)
Tracy
TracySlatten is offline
Old 03-08-2011, 09:55 AM
  #6525
Dang it Sean, play nice!
Tracy, take the top stuff off of the car. Lay it flat on the set up board. With your finger tips, twist-pivot the side links to see if they move freely. If not, loosen the football nuts and then check the side links again. If they are still snug, loosen the 2-56 screws that suck up the pivot play and check again. If they are still snug, pop one end of the link off and find out which pivot ball is guilty then tighten up the 2-56 more then normal and hit that side with a heat gun. Let it cool and then loosen the 2-56 for a correct fit. Reassemble everything with the football still loose, lay it flat on the board, sneak up snugging the football nuts and then go for the final tightening. Now check for over all pod feel.
If that fails, pull the football out and break it down, clean it, rebuild it, etc. Tension the 2-56 screws for a smooth operation.
I should have a spare lower plate in my stash.
