Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree374Likes
Old 10-18-2010, 05:51 PM
  #4501
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by skypilot
lipo, what lipos??
yea theres two TP packs in the box, I have it listed for $150.00 its been ran twice one at the hanger in 1.12 and once at FW in wgt, but I don't think this is the one you want, I'm pretty darn sure its for Mod only, the stock spec is the one you want, and it doesn't really mean spec as in zero timing, just that it has 'specs' built in for stock racing. (timing). Jaybee can confirm this has he talked to keven H at TZGP about it. little help here JB.
Originally Posted by Korey Harbke
The LRP SXX V2 has boost and feel adjustments, much like the SXX Stock Spec. The timing profiles in the "boost" adjustment are WAY more mild on the V2 vs the Stock Spec. They are were specifically designed for modified racing on larger tracks where they can benefit from a little extra top end power. Much like Speed Passion's 528_mod software. The SXX Stock spec has some very aggressive timing profiles in comparison... and would most likely start popping motors or itself very quickly if used with a full blown modified motor.
-Korey
what they don't tell you is its 2wd and 1/12 MOD. lol.
Correct guys....
Run the LRP SXX v.2 for No Boost STOCK racing or MOD. This speedo was specifically made to run MOD motors.....per Kevin Herbert
http://www.lrp.cc/en/products/electr...egler/details/
Run the LRP SXX Stock Spec especially for STOCK racing....per Kevin Herbert
http://www.amainhobbies.com/product_...Control-MK-III
JayBee is offline
Old 10-18-2010, 05:59 PM
  #4502
fjm9898's Avatar
how i am reading this is that the v2 would be the ideal speedo for wgt running a 10.5 class over the stock spec
just saying that since it says 12th and wgt is basically the same only a little larger. that i and i think a 10.5 with timing added is a mod class, lol.
or am i still reading this all wrong
fjm9898 is offline
Old 10-18-2010, 06:04 PM
  #4503
JayBee's Avatar
The ideal speedo from LRP is one that can run all motors!!
JayBee is offline
Old 10-18-2010, 06:06 PM
  #4504
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Frank,
In a nut shell, the V2 is great for no boost any motor or mod in either 12th or wgt or 1S classes. If you travel to a track that uses boost, you will be dead in the water. There is a profound difference between boosted and not.
Slapmaster6000 is offline
Old 10-18-2010, 06:09 PM
  #4505
JayBee's Avatar
Originally Posted by Slapmaster6000
Frank,
Correct here Frank....I found this out at the TZII GP. I had to buy a Tekin to keep my weekend going....running MOD 1/12th was not an option
JayBee is offline
Old 10-18-2010, 06:11 PM
  #4506
OVA
OVA's Avatar
Trader Rating: 87 (100%+)
The bottom is , If you are going to run the Spec classes with the Turbo or Boost Timming the V2 is not the hot ticket.....
OVA is offline
Old 10-18-2010, 06:12 PM
  #4507
UberFalcon's Avatar
Trader Rating: 25 (100%+)
Default Raceday Schedules
From what I can tell on the SRCR website, weekday races start with setup at 5pm. What about the weekend/holiday schedules?
Jason
UberFalcon is offline
Old 10-18-2010, 06:23 PM
  #4508
fjm9898's Avatar
so the timing is there, just TOO mild for a 10.5 to make it competitive in the wgt class
is the stock spec to weak to handle the power of a 10.5? cuz that would only leave the tc spec left.
fjm9898 is offline
Old 10-18-2010, 07:13 PM
  #4509
Trader Rating: 37 (100%+)
Other than Jaybee....sort of...has anyone suggested the Tekin? It's got you covered, and their customer service has been top notch in my experience.
jubilee is offline
Old 10-18-2010, 07:14 PM
  #4510
Jason
Waaay earlier. Quals usually start at 9 or 10 am.
jubilee is offline
Old 10-18-2010, 07:18 PM
  #4511
fjm9898's Avatar
i have a tekin. i am just looking to get a lrp so i dont have to use a rx pack or booster for running wgt
fjm9898 is offline
Old 10-18-2010, 07:21 PM
  #4512
i have a tekin. i am just looking to get a lrp so i dont have to use a rx pack or booster.
Ahhh, okay. IMO the boosters are really no big deal though. One less pack to charge!
I agree no pack OR booster would be cool.
jubilee is offline
Old 10-18-2010, 07:28 PM
  #4513
Korey Harbke's Avatar
I would consider the SXX SS to be good up to 10.5 when you use the dynamic timing profiles. The SS will even work with full blown mod motors.. you just have to turn everything way down or off. That leaves the usable range of adjustment extremely small and not so awesome for full blown mod stuff.
The V2 is for mod (and zero timing classes). It has a wide range of adjustment for the range in which mod motors are happy.
As far as I know... the internals are actually similar. I'm not 100% on that though as I have yet to open them up.
Korey Harbke is offline
Old 10-18-2010, 07:35 PM
  #4514
skypilot's Avatar
Trader Rating: 14 (100%+)
I sell you the one I have I just wanted all the info out there.
skypilot is offline
Old 10-18-2010, 08:57 PM
  #4515
Speaking of ESC...
Anyone have something I can slap into my 1/12 for a week or two? I wanted to get a 1/12 rolling by the next NWIC race and it might be kinda tight on funds.
-Korey
