Seattle RC Racers/Hangar 30
#4233
yep.
/"CRC Pro-Cut 1/12th Gray-low 80/20 - 80% Yellow compound with a ring of Gray compound on the outside edge. Mounted on CRC High Roller 38 mm wheel. Great tire for 1/12th stock and modified! "
So does that extra 20% of yellow make all the difference then the suggestion using yellow rears versus the grey lo?
#4234
The Jaco orange and the CRC greylow are hi-brid tires of yellow inner with a ring of grey on the outside. You get the forward bit of yellow and the freeness of grey. Use them as a tuning aid when yellow is too hooked up at corner entry. Pink will be even more hooked up at corner entry then yellow. The greylow-orange tires can still chunk, but not quite as easily as yellow.
#4235
Grant
#4236
So got this piece of glass shelfing about 6 feet long and I'm thinking....boy wish I knew someone that could cut this into some pit boards.
#4239
Any one looking for a HB TCX?
Check it out! Local to. http://shop.highvelocityracing.com/c...?categoryId=29
#4243
#4244
What's a general starting FDR for 17.5 touring with no timing? I seem to remember running in the 5's ... ?
