Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree344Likes
Old 09-23-2010, 11:34 AM
  #4216
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Slapmaster6000
No fear.
Does anyone feel like the 12th B Main at the Hanger is going to be hard to get into on the 13th?
Hmmm ...Its all about dreaming BIG!
JayBee is offline
Old 09-23-2010, 11:49 AM
  #4217
Trader Rating: 37 (100%+)
Thanks guys.
jubilee is offline
Old 09-23-2010, 12:04 PM
  #4218
Suspended
Was mulling over the idea of trekking down to TZII to do a little practice. Thats alot of gas for a one day trip, so anyone feel like a carpool situation?
Grant
tutankhamen is offline
Old 09-23-2010, 12:19 PM
  #4219
JayBee's Avatar
Grant
I was thinking the same thing
JayBee is offline
Old 09-23-2010, 07:12 PM
  #4220
Big thanks to everyone for the very helpful and informative evening! Special thanks Todd for putting the seminar together and Brian and Mike for sharing their knowledge. Extra special thanks to Kody for the great job wiring up my speed controller! Things turned out much better than my wiring plan. I would have probably had so much tweak in the car from the sensor wire and motor wires that I'd have had to run unmatched side springs to try to fix it.
I need to go through my notes and post a couple questions because I think I'm missing a few details. A couple that come to mind are what's the recommended starting front tire diameter if you're running a larger 1.80" rear configuration and what was the minimum recommended length on an AE .020" front spring before it's tossed.
One more that I thought of on the way home: Is it reasonable to offset the LiPo battery left or right a bit to help balance the car? My batteries (ProTek I think) don't have bumps on the bottom so I'm going to probably use servo tape and lexan to make some "keys" to lock them into the battery slots. I'm sure the left side will be heavy (Novak Havoc 1S ESC) and I could probably put the battery 3-5mm to the right before I get near the side link. Good idea or am I better off centering the battery and just balancing the chassis with a bit of lead once the car is all together?
CharlesWA is offline
Old 09-23-2010, 08:44 PM
  #4221
mkdut's Avatar
Trader Rating: 19 (100%+)
1.70 to 1.75 on the front tire. I would center the battery and use evrything else to balance the chassis. Brian will remember for me what the minimum spring height is.
mkdut is offline
Old 09-23-2010, 08:56 PM
  #4222
skypilot's Avatar
Trader Rating: 14 (100%+)
you don't need to key the battery in the slots, a simple piece of double sided scotch tape will hope it in place, or a couple of really small well placed pieces of servo tape.
skypilot is offline
Old 09-23-2010, 09:06 PM
  #4223
Suspended
Seems we are the only ones. . Altho most are like me and make a friday night secision.
Old 09-23-2010, 09:13 PM
  #4224
Logi Maker's Avatar
Trader Rating: 56 (100%+)
10R5 front wheel bearings, book says .125x.313. Can't seem to find that size.. does 1/4x1/8 fit/work?
Logi Maker is offline
Old 09-23-2010, 09:20 PM
  #4225
.125 is 1/8
.313 is 5/16
That's according to my calculator. I know nothing about pan cars.
EDIT: Maybe these?
http://www.avidrc.com/product/9/stan...-bearings.html
-Mike
grippgoat is offline
Old 09-23-2010, 11:31 PM
  #4226
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
I like to run about a 1 to 1.5mm split on tires or: 45.5 to a 44.0 or in Jack conditions 42 to a 41. Asc front springs come out of the package at .255-.250". I chuck 'em at .235". I would always center the bat as it's something that you usually can not move, then secure your electronics accordingly... add ballast weight as a last ditch effort.
Slapmaster6000 is offline
Old 09-23-2010, 11:34 PM
  #4227
I would be the first one leading the way, but it seems that I have a back log of actual "work" from taking that LV "week" off. What a pisser.
Old 09-24-2010, 12:00 AM
  #4228
oXYnary's Avatar
You know, I'm curious; back in the old days we mounted tires and such. Has anyone thought of making a dual shore rear tire thats 3/4 yellow to the inside with say a slightly firmer/less chunky outside?
oXYnary is offline
Old 09-24-2010, 12:38 AM
  #4229
Someone correct me if I'm wrong, but I think the CRC grey-lo serve this purpose.
jubilee is offline
Old 09-24-2010, 01:20 AM
  #4230
oXYnary's Avatar
yep.
/"CRC Pro-Cut 1/12th Gray-low 80/20 - 80% Yellow compound with a ring of Gray compound on the outside edge. Mounted on CRC High Roller 38 mm wheel. Great tire for 1/12th stock and modified! "
So does that extra 20% of yellow make all the difference then the suggestion using yellow rears versus the grey lo?
oXYnary is offline
