Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree369Likes
Old 07-01-2010, 01:48 PM
  #3391
Trader Rating: 37 (100%+)
I know it's only July 1, but with this early fall season I'm thinking about H30!
Any word from the Uber Committee on 2010/2011 classes, spec tires, tennis ball fuzz, grit, or pizza grease?
jubilee is offline
Old 07-01-2010, 02:45 PM
  #3392
Talk has slowed down as some are getting ready for Nats and others camping, biking and having a good time when the sun will allow. Every thing is just talk with ideas bouncing around at this point. Nothing has been set in stone.
Kody is offline
Old 07-01-2010, 02:55 PM
  #3393
mkdut's Avatar
Trader Rating: 19 (100%+)
All I can say is
mkdut is offline
Old 07-01-2010, 05:52 PM
  #3394
Rdog's Avatar
Trader Rating: 83 (100%+)
Originally Posted by JayBee
I have 3 choices to choose from now
Well Ill prob end up buying all 3
Rdog is offline
Old 07-01-2010, 08:18 PM
  #3395
JayBee's Avatar
Trader Rating: 31 (100%+)
There's like 5 or 6 now Randy.... Corally, HB, Serpent, Kyosho (can't get it here), Associated and rumors of a new XRay. DAMN!!
JayBee is offline
Old 07-01-2010, 08:52 PM
  #3396
Rdog's Avatar
Nice...Ive kinda got my eye the Associated car looks pretty cool.
Rdog is offline
Old 07-01-2010, 10:05 PM
  #3397
Yeah, I'm thinking asc or xray.
jubilee is offline
Old 07-01-2010, 10:12 PM
  #3398
mdowney's Avatar
Trader Rating: 21 (100%+)
I've finally got my new T3 up and running but I'm finding that the front drive belt vibrates a lot when I give it power while the wheels are turned all the way left or right. Would that be normal or did I screw something up when I put it together? I have the travel set well and nothing appears to be rubbing in the wrong place.
In case it matters, running:
Tekin RS Pro, 21.5T Redline
84T Spur, 28T Pinion for an FDR of 5.1
40C/4200mah lipo
Everything else is stock (EU model)
mdowney is offline
Old 07-02-2010, 10:06 AM
  #3399
Or TRF.
jubilee is offline
Old 07-02-2010, 10:51 AM
  #3400
Suspended
40C/4200mah lipo
At full steering lock touring cars have a tendency to chatter in the front wheels, this might be what your seeing translated as belt bounce. It is amplified when the suspension is unloaded, especially if there is a lot of up travel (droop) in the suspension and the arms are hanging down when you have it up in your hand.
So it's "normal" but not desirable. If the wheels themselves do not appear to be "bouncing" back and forth at full lock I wouldn't be as concerned, just check your belt tightness. Personally I've always run a belt as loose as possible before it skips.
You can calm down the chatter with different drive shafts. Losi, XRAY, and others make a double jointed CVD that smooths out the front end. I think the XRAY one is called a ECS shaft? Someone correct me if that's wrong. They make the front end smoother at full lock; but are slightly less durable.
Wes Briscoe is offline
Old 07-02-2010, 10:52 AM
  #3401
Suspended
Or TRF.
The Robotronics AVID2 looks nice as well....the red makes me think Top Photon, but it looks like it doesn't come prepackaged with all the suckage that the Photon has..
Old 07-02-2010, 11:24 AM
  #3402
skypilot's Avatar
Trader Rating: 14 (100%+)
skypilot is offline
Old 07-02-2010, 11:31 AM
  #3403
mdowney's Avatar
Thanks Wes! Good, I'm not so worried now. It's definitely amplified when I hold the car in my hand so it'll probably be ok for now.
mdowney is offline
Old 07-02-2010, 01:29 PM
  #3404
el salvador's Avatar
Cool "Suckage"?
"suckage"
Doesn't HobbyTown USA/Evertt have that item on special, "As I Type"?
el salvador is offline
Old 07-02-2010, 02:00 PM
  #3405
JayBee's Avatar
oops
JayBee is offline
