Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree369Likes
Old 11-24-2009, 02:33 PM
  #1951
mkdut's Avatar
Trader Rating: 19 (100%+)
Originally Posted by JayBee
Which Tekin Mike?
Running the RS myself. Motor limit is 5 turn for 4 cell. I ran it with a 6.5 and a single cell lipo and the speedo never got above 125 degrees
mkdut is offline
Old 11-24-2009, 04:02 PM
  #1952
Suspended
Default my bad
Originally Posted by Kcdzim
I think if you look close it is in fact trimmed with all the movie logos including the decepticon badge in the police shield on the front quarterpanel.
One hopes it will not be a bad omen to choose the only decepticon to inexplicably not be able to finish not only the chase, but the movie as well.
You are quite correct.. I did not look close enough.
tutankhamen is offline
Old 11-24-2009, 04:04 PM
  #1953
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks Mike.....everything should be here by Friday
JayBee is offline
Old 11-24-2009, 04:30 PM
  #1954
Goingfast's Avatar
Trader Rating: 29 (100%+)
Hey Sean Yep ! it is ready to go
Attached Thumbnails Seattle RC Racers/Hangar 30-12r5.1-001.jpg   Seattle RC Racers/Hangar 30-12r5.1-002.jpg   Seattle RC Racers/Hangar 30-12r5.1-003.jpg   Seattle RC Racers/Hangar 30-12r5.1-004.jpg
Goingfast is offline
Old 11-24-2009, 04:49 PM
  #1955
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
You guys are resourceful. I knew better prices could be found. You are definitely right to wait and see what the new track will need. I like the square tubing that Todd brought in the other night, but the red stripe will smear off onto our bodies when we rub up against it. Especially when I drive Dutemple into it! He drives a red body anyway, so that's like a freebie.
Slapmaster6000 is offline
Old 11-24-2009, 04:57 PM
  #1956
mkdut's Avatar
That would actually require me being able to get around you. Stock up on spurs I'm putting the Bodine tear away front nose on my car.
mkdut is offline
Old 11-24-2009, 05:04 PM
  #1957
Suspended
Default Silver can gearing
Using a stock TA-05 for spec class and was wondering what gear ratio I should run. Have a small assortment of spurs and pinions so not sure what is optimum for silver can. All far as I know they do not have alot of torque so greater gap between spur and pinion?
Grant
Old 11-24-2009, 05:10 PM
  #1958
PutAwayWet's Avatar
Grant
Hey Grant,
It's still pretty hard to beat a 5.5 Final Drive Ratio as a starting point. Standard TA05 internal ratio is 2.25, so choose your spur and calculate thus:
spur/5.5*2.25=pinion
Hope that helps.
Todd M.
PutAwayWet is offline
Old 11-24-2009, 05:27 PM
  #1959
Suspended
Default thanks
Originally Posted by PutAwayWet
Hey Grant,
Hope that helps.
Todd M.
Thanks Todd. That helps alot. Forgot what it was at SIR. . Running just over four right now and smoked a battery up in skagit. See you Wednseday.
Grant
Old 11-24-2009, 08:13 PM
  #1960
Default Howdy
Grant
Me: Ran a 40 pinion & 100 tooth spur. It was o.k.
Friend: Ran 42 & 100. He won. Motor barely got warm.
Me: So I ran 44t & 100t spur and was slower than before and motor was WAY too hot. Kent also ran 5.1 ratio and didn't win either.
5.3:1'ish seems to be good. Been looking all over town for a 42 tooth pinion since last race. I've also learned my motor is tired so that could have been a factor. but Kent didn't win either, ruling out much of the motor idea. I'd go 42tP & 100t spur.
aarontaht is offline
  #1961
I've been quietly working on my tire spikes and oil releaser, but the timing has been all wrong. So in the meantime, I have the brake full punch for random brake checks.
Old 11-24-2009, 09:50 PM
  #1962
gwhiz's Avatar
So...
Really looking forward to racing tomorrow.
I have an appointment in Bellevue at 3:45, and I hope to start heading back to the west side by 4:45. Everyone who has tried that knows how hopeless it can be to cross one of those bridges during rush hour. So if I am late, please sign me up for mod and stock touring.
I guess I can sauce my tires in the parking lot (floating bridge).
See ya soon!
-G
gwhiz is offline
Old 11-24-2009, 10:03 PM
  #1963
Default Newb entry in Novice
Greetings,
My name is Mike Ruete (like "Booty" with an "R"). I've been lurking for a few weeks, and I thought I'd say hi to everyone on here so that hopefully some people will say hi at the Hangar tomorrow. After looking at how much I spent doing track days this year, and how much it'd cost to go club racing with my real car, I decided to give R/C racing a try. Dividing all the number$ by 10 or more sounds good to me. It's more fun working on the little cars anyway, and you don't have to find somewhere to park the tow vehicle and trailer.
I've attached some pics of my car. The first is more than 8 years ago when it was new and not busted. The body's seen some abuse since then, but I hate painting, especially in winter, so it'll have to do.
I've prepped the car for Scale Spec/RCGT according to the Race Bible on the website, so I can get a good idea of just how slow I really am. My car is quite heavy, too, with the NiCd/NiMH batteries, and heavy plastic chassis. I'll be happy if I can just finish all the sessions with the car in one piece.
Details:
Chassis: HPI RS4 Pro 3
ESC: Tekin RS (still on 198, need to get the new flash)
Motor: Tekin Redline 21.5 Brushless
Radio: JR XR2 75mhz AM (channels 90, 84, and some Hitec 74 that seem to work)
Batteries: 2x old 2400mah NiCd, 1x new 3600mah NiMH
Tires: HPI 4790 (x-pattern radial, D compound) with stock inserts
Wheels: HPI TE37 26mm 0mm offset
Thanks to Sean and the other guys at Remote Control Hobbies in Woodinville for dealing with all my newb questions.
I'll be looking for all the advice I can get on everything (driving, setup, prep, etc). I'm also hoping to check out some other chassis, as I'd like something newer, lighter, less sloppy, better balanced, with all hex screws and parts that are easy to get.
-Mike
Attached Thumbnails Seattle RC Racers/Hangar 30-oldhotness.jpg   Seattle RC Racers/Hangar 30-newbusted.jpg   Seattle RC Racers/Hangar 30-bodyoff.jpg
grippgoat is offline
Old 11-24-2009, 10:57 PM
  #1964
Grant
OR if you don't feel like doing the math, someone pointed me here a while back. I printed it out and stuck it in my tool box. I am running Robinson 64 pitch:
http://www.arroyoc.com/index.cfm?fus...=Gear&Plot=mid
Or Build your own chart: http://gearchart.com/index.cfm?fuseaction=chart.create
rknott is offline
Old 11-24-2009, 11:07 PM
  #1965
Sixgears's Avatar
Trader Rating: 32 (100%+)
Are we talking in 64p? If so I have a 42t pinion you can borrow to see if that's the sweet spot...
-Dustin
Sixgears is offline
