Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree369Likes
Old 11-09-2009, 06:29 PM
  #1711
Trader Rating: 84 (100%+)
i think it is just a waste of money another ridiculously overpriced item to go along with the overpriced toy cars now a days.
jeff jenkins is offline
Old 11-09-2009, 08:38 PM
  #1712
Suspended
Default dumb question
Just have to throw out a dumb question here. Just wondering what most people are running for spur and pinion gearing for stock TC. I am currently running a 96 spur and 39 pinion for an FDR of 4.18. Current temps at the hanger run 105 to 120. If I am not mistaken good temps for brushless are 140-160? If I understand correctly than I could easily gear up. My other question is this: If I want to gear for faster straight speed but slower acceleration in the infield which way would I go? Bring the two gears closer to the same size or farther apart? Just throwing some things out there.
See ya'll wednsday.
Grant
tutankhamen is offline
Old 11-09-2009, 08:45 PM
  #1713
240zron's Avatar
Trader Rating: 30 (100%+)
Will there be someone selling the Jaco blues weds night?
240zron is offline
Old 11-09-2009, 09:01 PM
  #1714
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
The Hanger did have a stash of Blues for sale, proceeds supported the club. Todd can verify is there is stock left.
Slapmaster6000 is offline
Old 11-09-2009, 09:16 PM
  #1715
skypilot's Avatar
Trader Rating: 14 (100%+)
See ya'll wednsday.
Grant
well, in my humble opinion, if your running 12.5's at 120, and you gear up and are still running 12.5's but the temp is now 160 whats the point.
another thing is different brand motors do run better at different gearing, if you want you would be safe to go up at least two teeth on the pinion. this 'should' give you more speed on the straight, but it 'may' also give you more bottom end for the infield. despite what some will tell you, spur/pinion combo DOES make a difference in the feel of the car. if you have the options, set your gear around 3.8 with a 96 spur, and then if possible to get a 3.8 with a 106 or 110 try that. you should feel a difference in off power corner speed, drag brake, and accelleration. all in my opinion.
btw i to am running a 96 spur in 17.5
skypilot is offline
Old 11-09-2009, 10:15 PM
  #1716
Rdog's Avatar
Trader Rating: 83 (100%+)
Hey guys what a good starting roll out for my 13.5 1/12th scale? Thanks a lot trying to make the hanger this week.
Rdog is offline
Old 11-09-2009, 10:34 PM
  #1717
corallyman's Avatar
Trader Rating: 101 (100%+)
Rdog,
Brian and Mike and a few others are more informed than me, but I do know that 80mm or so would be a good starting point. If your speedo is a Tekin and you have the version with Turbo them maybe gear more like 65 or 70mm.
I am sure this question will be answered by a few more of the Hangar's finest.
Steve
corallyman is offline
Old 11-09-2009, 11:09 PM
  #1718
Default hey..again seattle racers
hey this is stewart. some of you know me when sir was still around. havent been doin any racin cause i been debating weather or not to drive to hanger 30. but i think im coming to my conculsions. i was the one always crashin into people till i figured out how to drive. lol
im lookin for a brushless setup. esc and motor. not sure what i want. but a good setup would be nice. i still have my ifs. i also have a 1/12 crc chassis carpet knife for sale if interested. 2 bodies. 1 set of new tires and 1 used. one built battery pack and 2 unused i think. comes with esc also. any info on how to start racin up there would greatly be appreciated. i get off work at 5. so hopfully i can make it there from renton on time.
vwman85 is offline
Old 11-10-2009, 05:57 AM
  #1719
mkdut's Avatar
Trader Rating: 19 (100%+)
Randy 75 to 80 rollout should be a good starting point depending on how the speedo is set up. I was at a 79 at TZII with a lot of timing advance in the ESC. Others were higher in the mid 80's but with less timing advance. I will probably drop 2 or 3 teeth to run on Weds.
mkdut is offline
Old 11-10-2009, 09:02 AM
  #1720
PutAwayWet's Avatar
Originally Posted by mkdut
ROAR cannot stop it without actually changing their rules. Once it's released to the general public there are no rules governing the ESC. Also, I would not call it a no brainer to switch. It's more like the flavor of the month. The last big national race it was the Tekin and the next one who knows.
You're right, of course, I should have written more carefully. Excepting batteries, ROAR is not in the electronics-approval business. They don't have the equipment or budget to undertake such an effort. However, ROAR is adding to the rulebook to clarify things. Voltage to the motor will be limited to 8.4v for 2S, and 4.2v for 1S. Expect it in the next rulebook if not sooner via addendum. If it is discovered--presumably through commercial competitors reverse-engineering the unit--that the Black Diamond is stepping up voltage, ROAR will intervene.
Anyway, why am I hijacking this thread?!
Todd M.
PutAwayWet is offline
Old 11-10-2009, 09:07 AM
  #1721
PutAwayWet's Avatar
Hey Stewart! Good to hear from you. We're running a Novice class which looks a lot like GT3 from your SIR days. Either the silver can you have or a 21.5 brushless setup would be good to get back in the groove. If you're looking for a good transition out of Novice, Scale Spec is probably just right. But come on down, see what's going on, run Novice with what you have, and take it from there. You shouldn't have any problem making it up here. Plenty of guys are rolling in at 6pm, and Q1 isn't until 7pm.
Todd M.
Old 11-10-2009, 09:09 AM
  #1722
skypilot's Avatar
if the ESC is banned, does Hanger 30 plan on following roars lead, or will it continue to pick and chose which roar rule to follow?
skypilot is offline
Old 11-10-2009, 09:17 AM
  #1723
mkdut's Avatar
I would imagine that the answer to your first question is yes. As for the second send me a PM with the specifics.
mkdut is offline
Old 11-10-2009, 02:56 PM
  #1724
Sixgears's Avatar
Trader Rating: 32 (100%+)
All this talk about rollout made me realize that I have no clue where to start....
1/12
Sphere
17.5 Duo
If I understand correctly, the lower turn the motor is, the more RPM it should be spinning...? Using that as a guide and what you guys have recommended as a starting point for 13.5, I should shoot for around 85ish? Way off?
Sixgears is offline
Old 11-10-2009, 03:00 PM
  #1725
mkdut's Avatar
1/12
Sphere
17.5 Duo
85 is probably the low end of where you want to start. Middle of the road would be 90.
mkdut is offline
