Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree374Likes
Old 10-29-2009, 08:38 AM
  #1621
Trader Rating: 37 (100%+)
Good times last night guys. Think the dots are a good idea in the long run, but will take some getting used to (for me, at least). Last night was proof positive I've been using the pipe to keep my car corralled in the track area. If anyone had any doubt as to the flying capabilities of a 1/12 car...
See you guys Saturday!
jubilee is offline
Old 10-29-2009, 08:51 AM
  #1622
mkdut's Avatar
Trader Rating: 19 (100%+)
You need to change your screen name to "Big Air" I managed to leave the track once but not quite as dramatic as you.
mkdut is offline
Old 10-29-2009, 10:02 AM
  #1623
PutAwayWet's Avatar
Default Wednesday Results
Another good night at the Hangar. Thank you to all who came out. We had two full heats of 1:12. When we were lined up for the first qual, Bill Evans nudges me and says, "Look at all those 1:12 scales," and I say, "Dude, I know." Awesome.
So, we laid down more dots last night and all in all it went well. The temptation when things change is to blame every misfortune on the change. In our case, when a car rolls a dot, it's as if that car had never before stuffed a pipe. Or if there is a collision between two cars, that no collision under other conditions had ever occured.
My thinking is this: the ease of setup and teardown, particularly as we look forward to a bigger track, is the single biggest factor in this club's long term success. It carries significantly greater weight in my calculations than race classes, tire specs, motor this and that, and the other stuff we like to yell about. If the effort to build the track becomes too big a burden, then it's easier to stay home than show up. That, more than anything else, will end the program.
Some may argue that mayhem is no fun either and will also will keep people at home. It is a risk. However, I believe it is a manageable risk. Good attitudes and accurate assessments are our best allies. Last night was far from mayhem. By comparing lap times in all classes, and the actual results on the track, I will say that there was no net effect on the racing. The dot launch (and there were not many) is no more effective at breaking cars than a fixed pipe. Both can and have occured. Head-ons do occur, but the biggest head-on risk has been, and will remain, a spun out car self-marshalling and going backwards on the track. Dot or pipe, that is the biggest head-on threat, and it is no more likely with dots than pipes.
Setup and teardown are our challenge. And given last night's quick work at teardown, I would say we have it well in hand. All signs continue to point to GO!
Todd M.
File Type: txt
File Type: txt
File Type: txt
PutAwayWet is offline
Old 10-29-2009, 10:20 AM
  #1624
oldrcr's Avatar
Trader Rating: 46 (100%+)
I like the dots.
was thinking about a center piece with velcro mounted would cause problems stacking them, so, maybe an edge treatment to make them grab the carpet. I have some ideas...
-Alex
oldrcr is offline
Old 10-29-2009, 10:45 AM
  #1625
mkdut's Avatar
I like the dots and the strategically placed pipes for use in the infield but one thing that needs to be addressed is dot/pipe location. For better or worse most people are going use the pipes leading up to the dots as a guide(including myself). If someone is running parallel along the pipe they should not be able to hit a dot when they get to the end of said pipe(without actually turning into the corner). Unfortunately this is what lead to a few of the more dramatic exits from the racing surface last night. Todd fixed the issue just past the loop but the corner coming onto the straight needs to be fixed as well.
And just for the record I like heads up starts better. I'm just sayin, no need for discussion, just happy to have a track to race at.
mkdut is offline
Old 10-29-2009, 10:51 AM
  #1626
gwhiz's Avatar
Default ...
What the heck, I will throw my dot observations into the mix.
I didnt like them at first. In fact I predicted mayhem. But it didnt really turn out that way, did it?
Personally, I think there is something to learn from the absence of an impassable boundary: accuracy. A pipe doesnt really force one to learn to approach that boundary with delicacy. At least on the inside of a turn, there is not much of a penalty for grazing the boundary if it is a traditional pipe.
I also like the "risky" aspect of the dots. I mean you can shave a little time here and there by putting your unwieghted inside tires on the edge of the dots, but if you get just a smidgen too greedy you end up paying for it.
It seems there is a little bit of a gambler in me after all, and I see the dots as a new challenge to explore as a risk -vs- reward scenario. And there is this fringe benefit of being able to see slightly more of your car when the boundary is in the line of sight between you and your car.
So I have come to like the dots. The only negative thing I havent seen or heard being addressed is the transition between a dotted boundary and the existing pipes. That transition can be a painfully abrupt one. Maybe we can do something with the flapper material on those pipe ends to smooth it out?
These are just my opinions. I am not looking to change anyone's mind.
-G
gwhiz is offline
Old 10-29-2009, 11:50 AM
  #1627
Maybell's Avatar
THE HANGAR ROCKS!!!!!
Thanks to everyone for the good times and great racing!
Damb, it was great to run 12th scale again!
Thanks Todd!
Maybell is offline
Old 10-29-2009, 02:07 PM
  #1628
PutAwayWet's Avatar
Default Looking Ahead: 1st Half 2010/2011 Season
Here are the dates for the first half of the 2010/2011 season. That's right, one year ahead. The hangar is a busy place.
2010
Sep 8 Wed
Sep 19 Sun
Oct 13 Wed
Oct 27 Wed
Oct 30 Sat
Nov 10 Wed
Nov 24 Wed
Nov 27 Sat
Dec 8 Wed
Dec 18 Sat
Dec 22 Wed
Dec 29 Wed
Old 10-29-2009, 02:51 PM
  #1629
beez's Avatar
Are we pretty much settling for just winter dates so that we don't compete with any of the outdoor programs?
beez is offline
Old 10-29-2009, 03:10 PM
  #1630
TracySlatten's Avatar
Hi folks,
Steve C, thanks for the info last night at the race, If you could hook me up with the e-mail to the fella with any of the delta parts, that would be appreciated. also if you run across a wing, or resistors... and I did not catch the name of the other person who was interested in the gear diff?
If anyone else has any novak servo's, 1/12 wings, resistors, or delta parts that they might want to sell, let me know. I have been trying to get my old cars going again.
Tracy
TracySlatten is offline
Old 10-29-2009, 04:29 PM
  #1631
Summer carpet racing would be fun too.
jubilee is offline
Old 10-29-2009, 05:02 PM
  #1632
I vote thumbs up on the dots!
botman is offline
Old 10-29-2009, 05:27 PM
  #1633
skypilot's Avatar
Trader Rating: 14 (100%+)
Todd M.
Its Deja Vu all over again, sounds a lot like when SIR had curbs. Lets talk on Saturday.
skypilot is offline
Old 10-29-2009, 05:54 PM
  #1634
mkdut's Avatar
No nearly as bad. Some careful placement of the pipes and it will be all good.
Now get back over to the TRCR thread and stir up trouble there.
mkdut is offline
Old 10-29-2009, 06:16 PM
  #1635
RcHammer's Avatar
Default missed out
Sounds like i missed out on all the fun.. well we still have saturday!!
Erik
RcHammer is offline
