Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Seattle RC Racers/Hangar 30 >
Like Tree374Likes
Old 09-09-2014, 07:29 PM
  #16246
your killin me ritchie. lol.
deleted that HUGE post. lol.
dragonracing is offline
Old 09-09-2014, 07:32 PM
  #16247
ok. hows this. leave everything as is but encourage (not mandatory)scale racing paint schemes. thats all im askin for. just makes the cars look better on track.
Old 09-09-2014, 07:34 PM
  #16248
metalnut's Avatar
Trader Rating: 36 (100%+)
You guys are essentially debating what's already in our updated rules: http://seattlercracers.com/specsrules/
There are better ways to up your post count or alleviate boredom at work
metalnut is offline
Old 09-09-2014, 07:50 PM
  #16249
Thanks you Adam for taking the time and reading our new Specs and Rules page.
K
Kody is offline
Old 09-09-2014, 08:02 PM
  #16250
skypilot's Avatar
Trader Rating: 14 (100%+)
cept I wasnt debating... just saying I aint doing it..
skypilot is offline
Old 09-09-2014, 10:08 PM
  #16251
metalnut's Avatar
Ok, non-rules related question. Can someone point me to a source of the thin rubber pads that people put under their lipos to prevent them from sliding around? I know they raise the lipo a bit, but my unicorn doesn't have battery braces and the Hudy tape isn't doing a great job keeping the battery in place. I can slide it about 1/8" forwards and backwards before the tape stops it.
Thanks!
metalnut is offline
Old 09-09-2014, 10:33 PM
  #16252
big al's Avatar
Potentiality stupid question here. .. What is a unicorn, in regards to rc?
big al is offline
Old 09-09-2014, 10:36 PM
  #16253
OVA
OVA's Avatar
Trader Rating: 87 (100%+)
The Answer is NOOOOOOOOOOOOOOOOOOOOO
OVA is offline
Old 09-09-2014, 11:17 PM
  #16254
metalnut's Avatar
Oh, that's just me being secretive for absolutely no reason whatsoever It's not really a unicorn, just a less common kit since it's "limited production". Think shaft drive that's not an Awesomatix and a pain in the butt to assemble. Oh yeah, and anodized blue
metalnut is offline
Old 09-10-2014, 12:43 AM
  #16255
RcHammer's Avatar
Thanks!
try a silly pad... or a cell phone anti skid pad.
RcHammer is offline
Old 09-10-2014, 05:07 AM
  #16256
skypilot's Avatar
Double sided Scotch tape. Also works
skypilot is offline
Old 09-10-2014, 07:51 AM
  #16257
Logi Maker's Avatar
Trader Rating: 56 (100%+)
Www.e-grips.com
Logi Maker is offline
Old 09-10-2014, 08:10 AM
  #16258
bradshawkyle's Avatar
www.shoegoo.com . I only use one battery all season, so it works just fine.
bradshawkyle is offline
Old 09-10-2014, 08:20 AM
  #16259
I have a prep-related question for the dinosaurs among us still running a belt drive chassis: do you have any recommendations on freeing up the drivetrain? I'm running a TC6.1 and TC6 and would really like to free things up as much as possible. I've already swapped bearings, so other ideas I've come up with include:
  • File plastic parts where bearings are installed to allow them to slip in and out more easily.
  • Switch from 48p to 64p gears.
Are any of these gonna help? Anything else I missed? Lastly, do any of you see a benefit from balancing wheels/tires in VTA? I tried it about a year ago with a prop balancer and some modeling clay and didn't see much of an improvement.
Old 09-10-2014, 08:53 AM
  #16260
Think you got the big ones there Kyle. I freed up my 6.1 and 6.2 with basically the same strategy. Where I found all my bind to be in the diff/spool. Sanding the outside edges of the cams is very helpful, but dont forget to shim up the bulkhead caps if needed as well. Best way to tell if they are free is to take the belts and dcv's off and give it a spin with your finger. If it's not extremely free spinning, start again. They should spin for a very long time. Also check the spur gear assembly, it can bind a little as well (just make sure the gear mesh isn't too tight, it'll cause a little bind as well). With those 3 things spinning freely you should be good. Then it's all about belt tension. I run em tight enough that they wont skip when slamming the breaks, but just barely. Depending on the type of bearing you are using, some people pop the inner seals out of the wheel bearings to free them up a bit. I use steel shield bearings so i dont have to do that.
Carnage9270 is offline
