Going to Seattle
Going to Seattle
I'll be in Seattle on business Aug 23-30, and I wanted to take advantage and check out Seattle Indoor Raceway. I will be at the Convention Center and from what I mapped out it's about 20 miles from where I'm staying to SIR. I'm taking a gamble here hoping that someone lives in the area of the convention center that might be going to the club race on Friday night Aug 24th and maybe I can hitch a ride as I won't have a rental while I'm out there. I know it's alot to ask so I will understand if there are no takers. I know a cab ride will be super expensive so I won't persue that I'll look into it when I arrive Thursday.
If there are some takers then PM me.
Thanks, Eric
Thanks, Eric
Thanks, Eric
Thanks, Eric
If you didn't bring any stuff we have track rental cars that people have used in the past just to get a chance to race while they are here.
If you are not able to find a ride, take a look at the bus schedule. Route 161 will get you to 43rd and Lind which is close. Or Route 150 will get you to 180th and Sperry which is a little more of a walk to the track but still under a mile. Here is the link to the bus schedules:
http://tripplanner.metrokc.gov/cgi-b....pl?resptype=U
Use the Convention Center as your starting point and 72nd & 180th in Renton as the destination.
Hope this helps.
Hope this helps.
from the convention center to SIR isn't that far. traffic doesn't back up until a little farther south, slight back up between I-5 and interurban exit off of 405. from 405 to track is 5 minutes. trip should be around 20 minutes total, unfortunately i won't be around seattle or i'd be happy to get you a ride.
bring your car and radio, someone will loan you a battery and charger. think they have some used tires left over from nats, unless you already have some 30 - 36 rps, or 32-36 sorex's.
just pull the batteries out of it and carry it on with you, we can probably scrounge up a body for you.
