Go Back  R/C Tech Forums > North American Regional Forums > Northeast Racing Forum
Radio Control Hobbies & Raceway - Waterbury, CT. >
Like Tree21Likes
Old 01-05-2015, 07:25 PM
  #29986
stickboy007's Avatar
Well, Tessman runs 100k in his HB center diff, as does Alex in his B44.3. I think Jay also runs 100k. That would seem like a good place to start, as I've heard that 60k is too loose.
BTW, Bman's, could you explain why less front droop would reduce front tire wear? Less front droop would basically limit lateral (during cornering) and longitudinal (during acceleration) chassis roll, which I expect would keep more of the front tire in contact with the surface and contribute to greater front tire wear. Unless the expectation is that more contacting front tire would even the wear out across the tire?
stickboy007 is offline
Old 01-06-2015, 03:16 AM
  #29987
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I would say 100k to start. 80 if you need less drive and 125 if you need more. I have been running 125 lately.
As for the front droop, not only will it help with on power steering but will help limit the rear weight transfer. If you have to much droop the front of the chassis will lift taking weight off the front tires. You'll have better rear traction of course but the front will just spin because of lack of pressure. Not saying that is the problem but merely something to look at.
Bman's 3XNT is offline
Old 01-06-2015, 07:29 AM
  #29988
R/C Tech Elite Member
EricW's Avatar
Both Xray and Xray team drivers are recommending 500,000 in the center diff for med/high bite tracks. Seems very high to me but what do I know.
The XB forum is having this discussion right now.
EricW is offline
Old 01-06-2015, 08:20 AM
  #29989
I see. So you're saying the front tire wear could be coming from excessive spinning of the front tires. Makes sense, but of course one would have to see how that trades off with more pressure on the front tires (less droop) leading to more wear. There's probably a window in there somewhere for optimal wear.
If you're going to run 500k in the center diff, you might as well make it a locked slipper...
Old 01-06-2015, 08:48 AM
  #29990
I would think 500k would be to much as well, unless it's carpet. I noticed a big difference just between 100-125k.
When I first started my center diff design I played with oils ranging from 5-125k. Of course starting low at 5k and working up. Everything under 50 was useless. Talk about smoking front tires!! As I went up tire wear got better. Went from both fronts to the most inside front. Once I settled on the middle I fine tuned front/rear oils. Right now I'm 7/125/5......
Old 01-06-2015, 01:12 PM
  #29991
dover67's Avatar
Willy B Can I put a AE T5m on pre-order?
dover67 is offline
Old 01-06-2015, 02:08 PM
  #29992
blwaz23's Avatar
I'm gonna run 100,000 in the center to start with and keep 8000 in the rear. In the front I'm gonna go up 1000 in the front to help with the tire wear. So 9000/100,000/8000. Then as time goes on and I get more familiar with the gear diffs I will make more adjustments.
blwaz23 is offline
Old 01-06-2015, 02:11 PM
  #29993
blwaz23's Avatar
T5 looks sweet. But I'm glad I went with the Xray
blwaz23 is offline
Old 01-06-2015, 02:13 PM
  #29994
blwaz23's Avatar
http://www.redrc.net/2015/01/yokomo-...it/#more-90981
Still wanna try this out one day.
blwaz23 is offline
Old 01-06-2015, 04:15 PM
  #29995
If you have to buy oil I would just buy 10k. Going up 1k is not that big of a difference. 10/100/8....
Old 01-06-2015, 05:53 PM
  #29996
blwaz23's Avatar
Sounds good.
blwaz23 is offline
Old 01-07-2015, 12:09 PM
  #29997
Regional Moderator
RobsRacin's Avatar
Getting things ready to head up racing tonight! See you all up there!
RobsRacin is offline
Old 01-07-2015, 09:10 PM
  #29998
TonyD.'s Avatar
Trader Rating: 44 (100%+)
Had a great time tonight. Thanx to Will, Jay, And Jeff. Rob and Larry had a great time in the bmain for 2wd buggy. My face hurts from the smile I had during the race. Awesome time. See you guys on sat.
TonyD. is offline
Old 01-08-2015, 07:16 AM
  #29999
Regional Moderator
RobsRacin's Avatar
Had a blast last night! Was having way too much fun in the Main. Tony, I'm coming for you next time!!! Be ready
Old 01-08-2015, 07:23 AM
  #30000
good racing last night. Good to race 4wd buggy again. Blake, you are really fast with that xray, especially considering you just got it. I'll make some adjustments and hit more 12 second laps next time I race you and Big Lux
Eaglesrx is offline
You have already rated this thread Rating: Thread Rating: 3 votes, 1.00 average.
