Iron Track Electric Hammer 1/18th 4WD Truck RTR RC Car >
Old 01-17-2017, 02:28 PM
Default Iron Track Electric Hammer 1/18th 4WD Truck RTR RC Car
+ YouTube Video
http://www.nitrorcx.com/16c-e18hm-hu...8-rtr-24g.html
Iron Track introduces its newest 1/18 scale Hammer Smasher Truck. This small scale monster truck has all the key features of bigger 1/10 vehicle such as shaft driven four wheel drive, durable differentials, oil filled shocks, and robust design. It's all packed into a robust machine that will fit in the palm of your hand. The Hammer is also fully equipped with a powerful brushed motor and electronic speed controller combo. The compact Hammer chassis lets you take on other road vehicles in wheel-to-wheel action, allowing you transform your yard into a fun offroad course!
Electronics:
2.4ghz Transmitter
2 in 1 Electronics Speed Controller and 2.4ghz Receiver
7.2v 800mah Ni-Mh Battery
370 Brushed Motor
1.1kg Precision Steering Servo
Features:
Molded protective gear cover
Molded tub chassis with optimized weight distribution
4 oil-filled rebuildable shocks with progressive springs
Special titanium anodized shock caps
Fully independent double A-arm wishbone suspension
Tough C-hub steering knuckles
Tough and efficient 4WD shaft driven drive train
Low friction ball raced bearing
4 high-traction multi-block tires
Attractive spoke wheels
Factory-finished pre-cut body
Front and rear molded bumpers
Twin point steering with integrated servo saver
Specifications:
Length: 250mm
Width: 170mm
Height: 120mm
Wheelbase: 164mm
Required to Run:
AA batteries for transmitter.
NitroRCX.com is offline
