1/14 Exceed RC Veteran Desert Trophy Truck Ready to Run 2.4ghz RC Remote Control Car >
Old 02-29-2016, 02:01 PM
Default 1/14 Exceed RC Veteran Desert Trophy Truck Ready to Run 2.4ghz RC Remote Control Car
+ YouTube Video
Additional photos can be found here
The Veteran is Exceed RC's newest Desert Trophy Truck creation. At 1/14 scale it is the perfect size for indoor and outdoor adventures. The Veteran is designed from the ground up with pure truck racing performance in mind. Features derived from rally trucks have been shrunken down in size and engineered to deliver the utmost performance in a 1/14 scale package. A composite chassis serves as the base of this desert truck. Mounted on the front and rear are aluminum shock towers towering over the metal geared differentials. Attached to the robust towers are oil filled shocks providing plush and ground hugging dampening. The steering tie rods and upper and lower arms are adjustable for fine tuning of the toe and camber, effectively altering the handling characteristics of this machine.
This truck has awesome power to weight ratio. The vehicle is easily propelled by the 380 sized high performance brushed motor. A brushed electronic speed controller delivers the current efficiently through an included 7.2v 1100mah Ni-Mh battery and charger. The brushed electronic speed controller is lipo ready and can accept 7.4v lipo batteries with a quick switch of a jumper switch. All of this power transfers through a shaft driven four wheel drive system providing ground clawing action through the performance wheels and off road spec tires. We recommend a Gens Ace 7.4v 1500mah lithium battery for an exponential increase in power and efficiency.
The Exceed Veteran desert truck ready to run package also includes a 2.4ghz radio system. With frequency hopping technology, interference is a thing of the past. No longer do you have to worry about your specific channel. The radio system will automatically take care of that for you while you are focused on handling this beast of a machine.
With a body designed with trophy truck looks off road performance, combined off road treaded tires. This scale looking machine will put a huge smile on your face when you see it four wheel power sliding through a corner spitting dirt and debris out the rear end.
Features:
1. Exceed design off road spec treaded tires
2. Exceed design trophy truck body shell
3. Oil filled adjustable shocks
4. Aluminum shock towers
5. Front and rear metal gear differentials
6. Brushed Exceed ESC lipo-ready
7. 380 Brushed Motor
8. 4WD shaft drivetrain
9. Adjustable servo with saver
10. Steel hinge-pins with protective bumper
11. Exceed receiver with 2.4GHz technology
12. 7.2V 1100mAh NiMH battery
13. 12mm standard wheel hexes
Specification:
Length:365mm
Width:194mm
Height:110mm
Whellbase:200mm
Gear Ratio:1:8.864
Ground Clearance:25mm
Motor:RC380
Servo: 6KG (Waterproof)
Battery:NI-MH 7.2V 1100mAh
Radio System:2.4G
Waterproof ESC/Servo/Receiver
Package Contents:
100% Assembled
1x 1:10 Exceed Veteran Trophy Truck
1x 2CH 2.4Hz Transmitter
1x Battery Charger (100-240V)
1x 7.2v 1100mAh Ni-MH battery
1x Instruction Manual
Required to Run:
AA Batteries for Transmitter
NitroRCX.com is offline
