1/14 Tacon Cavalry Desert Buggy Ready to Run 2.4ghz (Green) >
Old 02-26-2016, 02:08 PM
Default 1/14 Tacon Cavalry Desert Buggy Ready to Run 2.4ghz (Green)
+ YouTube Video
+ YouTube Video
Additional photos can be found here
The Tacon Cavalry is a 1/14 scale Desert Buggy. It was designed from the ground up with pure performance in mind. Performance features derived from 1/8 scale trucks and buggies have been shrunken down in size and engineered to deliver the utmost performance in a smaller buggy package. A 2mm thick aluminum chassis serves as the base of this buggy. Mounted on the front and rear is 2.5mm thick composite shock towers towering over the planetary geared fluid filled differentials. Attached to the robust towers are aluminum threaded oil filled shocks providing plush and ground hugging dampening. The steering tie rods and upper and lower arms are adjustable for fine tuning of the toe and camber, effectively altering the handling characteristics of the buggy over varying terrain.
This desert buggy has an awesome power to weight ratio. Weighing in at slightly over 2 lbs, the vehicle is easily propelled by the 380 sized 4500KV brushless motor. A 35 amp programmable brushless electronic speed controller delivers the current efficiently through an included 7.2v 1100mah Ni-Mh battery and charger. All of this power transfers through a shaft driven four wheel drive system providing ground clawing action through the performance wheels off road knobby tires. We recommend a Gens Ace 7.4v 1800mah lithium battery for an exponential increase in power and efficiency.?
The Tacon Cavalry Desert Buggy ready to run package also includes a 2.4ghz radio system. With frequency hopping technology, interference is a thing of the past. No longer do you have to worry about your specific channel. The radio system will automatically take care of that for you while you are focused on handling this beast of a machine.
The Cavalry has a roll cage body designed with durability and performance in mind, combined with a wing on the rear end, the buggy handles exceptionally well on bumpy terrain and responds quickly with throttle and brake inputs while mid flight off of a jump. The longer stroke rear shock mounted to the rear of the cage allows this buggy to have a bit more travel than its other brothers of the same class. This buggy will put a huge smile on your face when you see it four wheel power sliding through a corner spitting dirt and debris out the rear end or flying over triples easily correcting itself landing on the perfect transition.
Features:
1. Tacon design treaded tires
2. Tacon design slipper pad with adjustable gear cover
3. Aluminum-threaded, oil-filled, coil-over, 6061-T6 ajustable shocks
4. 2.5mm Thick composite shock towers
5. Front and rear metal gear differentials
6. Brushless Tacon ESC
7. 2838 4500KV brushless motor
8. 4WD shaft drivetrain
9. Adjustable mini servo with saver
10. Steel hinge-pins with rounded front bumper
11. Tacon receiver with 2.4GHz technology
12. 7.2V 1100mAh NiMH battery with 3.5mm gilded round connectors
13. 2.5mm anodized aluminum rear and front kick-up chassis with dirt guards
14. 12mm wheel hexes
15. Full body roll cage with spoiler
Specifications:
Scale: 1/14 Tacon Soar Buggy
Length: 304mm (12in)
Width: 202mm (8in)
Height: 110mm (4.3in)
Wheelbase: 186mm (7.3in)
Weight: 0.90kg (1.9lbs with battery)
Tire Type: Tacon Buggy
Chassis: 2.0mm anodized aluminum
Motor or Engine: 4500Kv 2838 brushless motor
Gear ratio: 8.23
Speed Control: Brushless
Radio: 2.4GHz Technology
Batteries: 7.2V NiMH with 3.5mm gilded round connector, Charger included
Shock Type: Aluminum-threaded, oil-filled, coil-over
Ball Bearings:Complete
Package Contents:
100% Assembled
1x 1:14 Tacon Soar Buggy
1x 2CH 2.4Hz Transmitter
1x Battery Charger (100-240V)
1x 7.2v 1100mAh Ni-MH battery
1x Instruction Manual
Required to Run:
AA Batteries for Transmitter
NitroRCX.com is offline
