Team Energy T8X 1/8 Scale Brushless Powered Ready to Run Racing Buggy 2.4ghz >
Old 02-26-2016, 01:53 PM
Default Team Energy T8X 1/8 Scale Brushless Powered Ready to Run Racing Buggy 2.4ghz
+ YouTube Video
Additional photos can be found here
Team Energy has developed an all new 1/8 scale racing chassis. This machine is built burly to handle tough terrain while its suspension and controls handle like a precision guided missile. This is a ready to run buggy that you can take to jumps for big thrills or take it to a track for top level racing competition. The T8X electric powered buggy has everything that a basher or racer would want packed into an amazing radio controlled racing vehicle.
The Team Energy T8X has a long list of performance parts, making for the best and lightest buggy on the scene. To start off, the T8X has a full 3mm thick 6061 hard anodized aluminum chassis. The new narrower chassis and side-guards shed weight compared to other buggies while allowing optimized weight distribution of the electronics mounting for improved overall handling.
The G8X also has fresh designed suspension arms featuring centerline shock mounts and an optimized anti-roll bar position. The new suspension arms were designed to work with the aluminum low center of gravity shock towers to improve and optimize the suspension geometry, making the G8X more plush and forgiving in rougher terrain. 16mm Big Bore aluminum and threaded oil filled shocks also help the buggy achieve maximum control over any terrain.
The drive train is also beefed up metal differentials and thick axle cups. Thick drive axles reach out to the wheel hubs with CVD joints in the front and traditional dog-bone style setup in the rear. There are no bushings on this vehicle, every rotating piece is treated with high quality sealed ball bearings for low drag and maximum rolling and rotating efficiency. Thick chassis braces mounted in strategic high leverage points ensure your hard jumps and landings do not warp or bend the chassis.
At both ends of the buggy, the T8X has everything you'd expect from an all-out competition kit, including thick anodized aluminum steering link with ackerman adjustment, adjustable roll center, thick adjustable turnbuckle links, aligned king pin and universal joint pivots, sway bars front and rear, steel adjustable turnbuckles, and adjustable shock mounting positions. There are tons of adjustment that can allow you to tune this buggy any way you want it handle. The factory settings are awesome straight out of the box for a wide range of running situations.
The T8X is a brushless powered buggy which means instant power unlike its nitro powered counterparts that require revving up an internal combustion engine. The power is ready to rock and roll on tap! A 14.8v 4000mah 45C battery discharges its juice into a 100amp waterproof speed controller. Spinning all that power is a 3674 2400kv high torque brushless motor. This setup tortures the pavement and dirt and makes wonderful dirt rooster tails.
All of the latest Team Energy kits are now fitted with a comfortable and feature-packed Dimension GT3X 2.4GHz radio system for supreme control and confidence. The radio features a pistol-grip design with 3 channel functionality, easy carry handle, fold-down antenna, end point adjustments, servo reversing, steering and throttle dual rates, steering and throttle exponential adjustments, and even channel mixing. It's also extremely lightweight due to it requiring only four AA batteries. The radio prevents frequency conflicts automatically and changes channels if there is any interference. You'll have professional-level control in one easy ready to run package.
The Team Energy T8X is a seriously awesome package. Elevate your buggy game to the next level with the new T8X ready to run kit, and drive what the winners drive!
Features:
Factory-assembled & pre-painted electric powered 4 wheel drive 1/8 scale buggy
New-look body with brand new Team Energy Design
High torque 13kg metal gear steering servo
2.4 GHz GT3X radio system for crystal-free comfortable control
3mm thick 6061 tough aluminum chassis
Dirt and stone guards keep rocks out of the rear suspension chassis
Hardened steel spur and pinion gear for extreme durability
Front, center and rear fluid-filled differentials
Suspension based on World Champion Buggy
Aluminum shock towers with multiple shock positions
16mm Big bore oil-filled aluminum threaded shocks
Long suspension arms give stability and balance
Sway bars front and rear give confidence while cornering
Steel turnbuckle links allow you to custom-tune handling
Adjustable toe-in for suspension fine-tuning
Sealed shaft drive train is maintenance-free and extra strong
All-terrain tires grip great on any surface
Fantastic-looking wheels
Durable adjustable wing for high down force
Powerful and Reliable 540L Class 2400kv Brushless Motor with cooling fin
100A Waterproof S8A Brushless Speed Controller
14.8v 4000mah 45c Lithium Polymer Battery
Specifications:
Type: Buggy
Scale:1/8
Width:11.8 in (300 mm)
Height:8.27 in (210 mm)
Ground Clearance:2.4 in (60 mm)
Wheelbase:12.8 in (325 mm)
Length:19.5 in (495 mm)
Weight (w/o electronic):5.7 lb (2.6 kg)
Weight (with electronic):7.75 lb (3.5 kg)
Chassis:3mm 6061 Aluminum
Drivetrain:4WD
Motor:
2400KV Non-Sensored Brushless 540L (size 3674, 5mm motor shaft)
Steering Servo:13 kg
Speed Control:Hobbywing Brushless 100A
Battery:4S 14.8V 4000mAh 45C Lipo
Tire Size:4.4x1.7 in (112x43 mm)
Wheel Size:3.43x1.57 in (87x40mm)
Wheel Hub:17 mm
Radio:2.4Ghz 3 Channel GT3X with LCD screen
Ball Bearings:Complete
Shock Type:16mm Diameter Aluminum, Oil Filled
Is Assembly Required:No
Speed (Approximately):
>34.2 mph (55 km/h) with 13T pinion gear
>46.6 mph (75 km/h) with 19T pinion gear
>68.4 mph (110 km/h), require 6S Lipo/Hobbywing 150A ESC Upgrade
Electronic Waterproof:Yes
Includes:
Pre-Assembled 1/8th Scale 4WD Buggy
2.4GHz Radio System
Painted Body
Wheel and Tires
Required to Run:
Charger for 14.8v Lithium Battery
4 AA Batteries for GT3X Transmitter
NitroRCX.com is offline
