1/8th (Blue) Exceed RC MadDrift Electric Brushless Limited Edition RTR Ready to Run R >
Old 01-11-2019, 03:27 PM
Default 1/8th (Blue) Exceed RC MadDrift Electric Brushless Limited Edition RTR Ready to Run R
https://www.nitrorcx.com/52c76-maddr...ss-limite.html
Exceed RC has raised the stakes by releasing their 1/8 scale platform on road car. The result is the MadDrift Brushless Drift Car. Ready to hit the streets right out of the box, the MadDrift Brushless Drift Car packs a long list of features and flaunts a distinctive look that will leave the competition in the dust.
This car is loaded full of features. Power is delivered through a high performance 540L 2150KV brushless motor and supported by an 80A Brushless Hobbywing electronic speed control. Enough power to deliver tire-shredding torque and reach the high RPMs needed for high-speed drifting. The 2.4ghz Radio system keeps the driver in full control. The limited edition features an aluminum chassis, aluminum shock towers, aluminum steering Ackermann. Oiled filled shocks and the included sway bars keep the car in control during hard cornering. The ESC is mounted right in the center of the car and the two batteries on either side of it to create the best possible balance and weight ratio for superb handling. All the features of this car scream performance in a ready to run package.
Features
Unique centralized low center of gravity design
Street-ready detailed and high strength drift body
Durable oil filled shock
2.4Ghz Pistol Transmitter
80A Brushless electronic speed control with 540L 2150KV brushless motor
Foam bumper for added protection from impacts
Easy access front and rear geared differentials
Includes 2 7.4V 3300mah Sky Lipo Batteries
Specs
LE/RE Model Number: TK1001/TK1002
Length: 620MM
Width: 310MM
Height: 175MM
Wheelbase: 330MM
Track width: 310MM
Gear Size: 12T Pinion gear
Gear ratio: 12.68:1
Radio: 2.4GHz
Motor: ?36 x 65 540L Brushless motor 2150KV
ESC: 80A Brushless ESC (Hobbywing)
Battery: 7.4V 3300mAh Li-Po
Servo: Metal geared steering servo
Needed to complete
4 x 1.5V AA Batteries for transmitter
Lithium Polymer Battery Charger
NitroRCX.com is offline
