SKY Hawkeye 1315S 5.8G RTF Return Home Quadcopter Drone with Real-time Transmission w
https://cimg2.ibsrv.net/gimg/www.rct...e3d3dfd537.jpg
https://cimg3.ibsrv.net/gimg/www.rct...5afaaa6c37.jpg https://cimg5.ibsrv.net/gimg/www.rct...b6c97bba24.jpg https://cimg4.ibsrv.net/gimg/www.rct...f0f06275b3.jpg https://www.nitrorcx.com/28h-1315s-v...-black-sd.html The Sky Hawkeye is an entry-level FPV quadcopter; it's good for beginner pilots learning how to perform FPV flight. The quadcopter features both headless mode and auto return at a push of a button. The headless mode feature means that once this mode is activated, pulling the direction of the stick back towards you will bring your aircraft back home to you no matter its orientation, front, back, or side. This makes flying back to you when you lose sight or flight orientation of it much easier. The auto return model is very nifty as well, once activated the quadcopter will automatically fly backwards of its heading. If you have the back of the quadcopter pointing at you and activate the feature the quadcopter will fly back towards in your direction. Each arm of the quadcopter has 4 LED lights to help you differentiate the orientation of the quadcopter. The quadcopter also features a flip function; once you press the flip button the quadcopter will automatically perform a flip. Dual rates can also be set via the transmitter, you can set the quadcopter to be more sensitive or less sensitive to input of the transmitter. Specifications: Li-po Battery:3.7V 700mHA(Included) Battery for Transmitter:4x1.5V AA battery(Not Included) Flight Time:5 mins Charging Time:60 mins Remote Control Distance:50 meters Size:40 x 40 x 10 cm Ages:14+ Features: Headless mode and auto return function 5.8GHz transmission systems Real time video transmission Fly up/down, turn left/right, forward/backward 360 degree flip flight Stable flying, easy to control Flashing light Indoor and outdoor flying Package Included: 1x SKY HAWKEYE Quadcopter 1x Transmitter 1x 3.7V 700mHA Battery 4x Propeller 2x USB Cable 1x LCD Screen 1x 4GB SD card |
