Exceed RC Off Road Buggy Radio Car 1/10 2.4Ghz Electric SunFire RTR Off Road Buggy (F >
Old 12-06-2018, 02:18 PM
Default Exceed RC Off Road Buggy Radio Car 1/10 2.4Ghz Electric SunFire RTR Off Road Buggy (F
https://www.nitrorcx.com/51c802-firegreen-24ghz.html
The Exceed RC Sunfire EP Buggy is packed with loads of features that will provide hours of action packed off road smashing. The 2.4ghz transmitter and receiver system ensures you will have excellent communication between driver and vehicle. The transmitter also allows dual-rate adjustments for throttle and steering so you can fine tune the power delivery and steering control of this buggy. The power-train is reinforced and will handle extreme terrain. Metal geared front and rear differentials are driven by an aluminum center driveshaft and distributes the power to all four wheels. The power department is handled by a brushed 540 motor and supported by a 7.2v 1800mah Ni-Mh battery with charger included. Camber and toe settings are adjustable via turnbuckle linkages which allow you to make precise adjustments for the terrain your buggy is smashing through. The high down force wing and knobby tires ensures this buggy is planted to the ground at high speeds. This buggy comes out the box completely ready to run with the exception of 4 AA batteries for the transmitter. Simply pull the buggy out, charge the battery and your ready tame the unknown.
Features:
Aluminum centre drive shaft
Powerful 540 Brushed Motor
Powerful Electronic Speed Controller
Large solid aluminum shock towers
High performance front/rear differentials
Adjustable front and rear suspension
Anodized aluminum radio tray
Oil filled adjustable shocks
Off road knobby tires
Stylish off road wing
Specifications:
Length: 400mm
Width: 250mm
Height: 160mm
Weight: 1410g
Wheelbase: 275mm
Ground Clearance: 26mm
Gear Ratio: 8.13:1
Diameter of Wheel: 86mm
Width of Wheel: 32mm
Battery: 7.2v 1800mAh Ni-MH
NitroRCX.com is offline
