WL Toys 2308 Double Side Stunt Car RC Remote Control Radio Car
https://www.nitrorcx.com/28c-2308-double-yellow.html
Have you ever driven your RC car and flipped it and had to walk over to flip it back? Well that’s a thing of the past thanks to the double sided design of the WL Toys 2308. The 2308 is a 360° rotating stunt RC car that can be drive on both sides. It has forward, backward, left, right, speed up, and 360 °rotation function. The transmitter can be used for charging the car, so never worry about running out of power while you’re outside playing. The transmitter has good anti-interference capability which lets you play comfortably and have more fun. This stunt car is very easy to play with and will give you good control at a high speed.
Specification:
Product Size: 4.3x3.1x1.5 inches
Control Distance: 10-15 Meters
Battery For Car: 4.2V 120mAh Li-Po Battery
Battery For Transmitter: 4*AA Battery (Not Include)
Charging Mode: USB or use of transmitter to recharge.
Charging Time: 50 Minutes
Charging Current: 140mAh
Discharging Voltage: 3.3V
Playing Time: About 7 Minutes
Age Range: Above 6+
Package Includes:
1x WL Toys 2308 RC Car
1x Transmitter
1x Transmitter Antenna
1x USB Charging Cable
1x Manual
