Exceed RC 1/8th Scale Star Green MadWarrior Nitro Powered led Truggy w/ .21 Engine, 4 >
Old 09-18-2018, 02:20 PM
Default Exceed RC 1/8th Scale Star Green MadWarrior Nitro Powered led Truggy w/ .21 Engine, 4
https://www.nitrorcx.com/52c65-madwa...mite-artr.html
Note: TX/RX are NOT INCLUDED
The new generation of 1/8 Truggy are here with much newly added features and functions. Everything from the ground-up has been reinvented and modified to enhance the delight of having fun with the RC once again.
This massive 1/8 MadWarrior Truggy comes with Level .21 engine for speed of swiftness, polished aluminum chassis to provide clean look as well as sturdiness, adjustable shocks to have perfect landing, a bigger fuel tank that can hold 150cc. The impressiveness of theMadWarrior Truggy can be seen right out of the box when examine at first glance from the well-built interior to the magnificent exterior designs. From the front bumper to the back bumper all pieces have been build to last. Included in the MadWarrior Truggy are aluminum muffler for superior protection and better looks, and heavy duty metal gear steering servo so you don't have to worry about it breaking. Even the rims are now hardened chrome rims and colossal tires to triumph over the world. Use the MadWarrior Truggy to climb off road terrain, stony hills, rocky backyards, or wherever the road may take you. For the MadWarrior Truggy will lead the way to new standards for the RC world and conquer all.
The 4WD Engine-powered Truggy MadWarrior will Push your Imagination into overdrive!
Engine 21 Level
WheelBase:15"
Weight:5.2kg
Polished 6061 Aluminum Chassis Plates
Massive pre-glued 5" Tires Mounted on Hardened Chrome Rims With 17mm Hex Hub
1-Speed Transmission
Heavy Duty Metal Gear Steering Servo
150cc Flip-top Fuel Tank
Adjustable Threaded Aluminum Shocks
**TX/RX are required
NitroRCX.com is offline
