Exceed RC Rally Truck Radio Car 1/10 2.4Ghz Carbon Blue Electric Short Course Rally M >
Old 09-06-2018, 12:53 PM
Default Exceed RC Rally Truck Radio Car 1/10 2.4Ghz Carbon Blue Electric Short Course Rally M
https://www.nitrorcx.com/51c809-carbonblue-24ghz.html
NEW 2.4GHz 1/10 Off Road Electric Rally Monster Racing Truck
The most popular 1/10 4 wheel drive electric power off-road buggy in the world just got better! At each evolutionary step, the Rally Monster EP is at the peak of the RC off-road Rally field. Now with 2.4G, you can race this machine with as many friends as you want! No more interference or waiting in line to play. Get in the action now!
The heart of the Rally Monster EP line has always been a reliable and consistent power for tough off-road driving.
RTR ¨C factory assembled with installed motor and radio gear makes getting started easy.
New lightweight suspension arms deliver quick suspension response and reduce the critical sprung weight and overall weight of the car.
Oil filled shocks with firm tuned springs keep the wheels on the ground.
The Rally Monster EP will be available "Ready-To-Run" making it the highest on-road performance 4-wheel drive Electric Power racing car available to everybody
Completely preassembled with high quality radio gear, painted, trimmed and ready to roll
The new powerful 540 Motor provides reliable and consistent power for high performance on-road driving
The 2.5mm lightweight aluminum alloy chassis provides excellent performance and durability
Excellent differential system design provides quick access to the front or rear differential by removing only few screws. You can now access the front and rear differential for easy maintenance
High capacity battery provides long run times
The high quality AM transmitter and receiver work together to let you precisely control your car.
Length:
400 MM 15.7 inch.
Width:
250 MM 9.8 inch.
Height:
160 MM 6.3 inch.
Wheelbase:
275 MM 10.8 inch.
Ground Clearance:
26 MM 1.02 inch.
Diameter Of Wheel:
86*32 MM (F) 86*40 MM (R)
Battery:
7.2V 1800mAh Ni-Mh
Motor:
540 w/ Heat Sink
Gear Ratio:
8.038:1
NitroRCX.com is offline
