Exceed RC 2.4Ghz Brushless Carbon Red Version RC Drift Star Electric Powered RTR Drif
https://www.nitrorcx.com/51c806-pro-...red-24ghz.html
The EXCEED RC Electric Drift Star model represents a new generation of 1/10 scale on road drift cars. This ready to run Drift Star car is electric powered and perfect for indoor or outdoor drifting. Based on our popular and durable on road electric powered car, this drift version adds specially designed solid compound drift tires pre-mounted on high performance wheels. Combined with a powerful programmable 45amp brushelss esc and brushless motor, this Driftstar is capable of extreme drift angles and speed. The Drift Star is equipped with a four wheel driven drive train for consistent drift action on a wide variety of surfaces.
It is also equipped with aluminum threaded shock bodies which allows the preload of the springs to be quickly and easily tuned. The camber and toe are also easily adjusted through the use of aluminum turnbuckles. These combined features allow the user to quickly and easily tune the suspension geometry, letting the user get the most out of the Brushless DriftStar platform.
Best of all, the motor and transmission are both completely sealed to prevent dirt and grime from getting in and causing damage. This motor has been proven to be both durable and reliable, making the new Drift Star a welcomed addition to the latest Exceed RC line.
Features:
The new KV 3300 Brushless motor provides reliable and consistent power for high performance drift driving
The 2.5mm lightweight chassis provides excellent performance and durability
Excellent differential system design provides quick access to the front or rear differential by removing only few screws. You can now access the front and rear differential for easy maintenance
New lightweight suspension arms deliver quick suspension response and reduce the critical sprung weight and overall weight of the car
High capacity battery provides long run times
The high quality 2.4Ghz transmitter and receiver work together to let you precisely control your car.
Four wheel drive system
Excellent front/rear camber and toe-in setup
Anodized aluminum centre long drive shaft
Stable suspension arms and solid front/rear shock tower
Precise steering fitting delivers quick response.
Complete ball bearings for a smooth and an efficient drive.
High performance anti-skid drift tires, chromes plated spoke rims and pre-mound drift wheels
Specification
Length:360mms
Width:200mm
Height:112mm
Wheelbase:260mm
Track:195mm(F/R)
Gear Ratio:6.52:1
Ground Clearance:4.5mm
Weight:Approx.1350g
Wheel:65mm(Diameter),26mm(Width)
Motor:Brushless 3300Kv
Battery: 8.4V, 3000mAH (Charger included)
Required to Run:
4 AA batteries for Transmitter
**Note**
45amp ESC is rated for 4-7s Ni-Mh batteries or 2s Lithium polymer. Using a battery with higher voltage can damage esc or motor.
