WLtoys V333 Green 2.4G 6 Axis UFO Quadcopter Drone RTF w/ Build in Camera RC Remote C >
Old 06-07-2018, 12:52 PM
Default WLtoys V333 Green 2.4G 6 Axis UFO Quadcopter Drone RTF w/ Build in Camera RC Remote C
https://www.nitrorcx.com/28h-v333-ca...ufo-green.html
The WL Toys V333 "Cyclone" Quadcopter is the perfect machine for those curious about quadcopters and drones. Designed with simplicity in mind, it is light weight and its flight characteristics benefit from this design feature. Constructed of durable materials and graphite booms the light weight enhances the crafts power to weight ratio. The 4 rotors are driven by 4 motors protected in plastic housings. The rotors are also gear driven which relieves the stress on the motors. The rotor blades are also protected by a molded foam shell that absorbs impacts and protects the blades during collisions with obstacles. The V333 handles exceptionally well. With the help of an on board gyro and adjustable control sensitivity, the V333 is perfect for pilots of different skill level and ages. This drone is agile, and it has the ability to do flips and tricks. With the push of a button on the transmitter the aircraft enter "trick mode" allowing the pilot to do flips and rolls. The WL Toys V333 transmitter features a 2.4ghz radio system. This means you don?t have to worry about signal interference and you have the ability to fly many of these at one time. A camera will come included with the unit inside the package, and can installed to the unit within seconds. It?s also compatible with the optional missile launcher, water cannon, hook & basket, and bubble blower accessories.?
The V333 Quad Copter is the newest machine from WL Toys. Its design will allow you to fly faster and be more agile in the air. The drone can be flown indoors or outdoors on calm days.
WL Toys V333 Features:
Latest WLtoys V333 RC quadcopter
2.4Ghz Transmission enables interference free operation
Full Proportional Remote Control with Built-in 6 axis GYRO System
Special design cover with durable material, provides more protection
High capacity battery included, provides longer flight time
Support missile launcher, water cannon, hook & basket and bubble blower
WL Toys V333 Specification:
Brand name: WLtoys
Item name: V333 RC Quadcopter
Frequency: 2.4G
Channel: 4CH
Gyro: 6 axis
Flight Duration: 8-10 Minutes
Remote Control Distance: 100-150 Meters
Recharging Time: 1-1.5 Hours
Battery For Quadcopter: 7.4V 850 mAh(included)
Battery For Transmitter: 6 x AA Battery (not included )
V262 Dimension: about 55 x 55 x 5cm
Package Included:
1 x WLtoys V333 RC Quadcopter
1 x Transmitter
1 x Battery
1 x Charger
4 x Propeller
NitroRCX.com is offline
