Syma X8HC Hover Headless Camera 2.4G 6-axis Gyro Quadcopter Ready to Fly+4GB Memory C
https://www.nitrorcx.com/56h-x8hc-hd...s-gold-sd.html
Syma RC introduces its latest X8HC Quadcopter! If you are familiar with the X5 series of Syma quads then the X8 is its bigger brother. All the awesome qualities in a larger package flight package. A quadcopter is a machine that is lifted and propelled by four rotors. Unlike most helicopters, a quadcopter use symmetrically pitched blades mounted on four motors to produce lift. Controlling the speed of these individual motors allows the machine to move forward and backward, up and down, strafe left and right, and rotate clockwise and counterclockwise.
The Syma X8HC 4 Channel quadcopter brings a new element to radio control quads and offers a completely different experience of flying. It offers a refreshing change on how to hover, balance, and control a copter. With the help of an 6 axis gyro, stability and agility is achieved effortlessly. Flying the Syma quad is simple and intuitive allowing the pilot to enhance their skills quickly. Once you enhance your skills enough there are stabilization settings built in that you can disable to advance your ability to fly the X8HC and perform 360 degree eversion.
The X8HC is equipped with an HD camera to capture all your flying adventures. Capture your footage and record video or take picture and save onto an SD card all from the push of buttons on the 2.4ghz transmitter.
With the use of 2.4ghz technology the Syma X8HC radio system has the benefit of longer control distance, strong anti-interference technology, low power consumption, and rapid response times. Using spread spectrum technology for further remote distance, best anti-interference ability, least power consumption. you could fly more helicopters at the same time, its reaction speed is 100 times faster than other radio control.
Now equipped with Headless and Hover Mode! The headless mode features means that once this mode is activated, pulling the direction of the stick back towards you will bring your aircraft back home to you no matter is orientation, front, back, or side. This makes flying back to yourself when you lose sight of it much easier. The hover mode allows the quadcopter to hover in one spot allowing the flight control to take over and achieve altitude hold. Now you don't have to keep adjusting throttle as much while you are recording or flying smoothly.
The Syma Radio Control brand is one that is very well known in the micro helicopter industry. Its quadcopters has been a hot seller mainly because of its stability and ease of flight. The Syma X8HC Quadcopter carries all of these favorable traits over from the other quads to produce a quadcopter in an awesome ready to fly package.
The Syma X8HC comes ready to fly with a 7.4v 200mah Li-Po battery and charger providing about 7-9 minutes of flight time per charge.
Main Features:
Low-voltage protection
Over-current protection
Level calibration function
3D overturning function
With orange and green LED light
Pressure hovering height adjustment function
WiFi real-time transmission aerial photo-taking / video recording function
Fine tuning function
Fling-fly action
Headless mode
Left and right hand throttle mode switch
Specifications:
Brand: Syma
Item No.: X8HW
Frequency: 2.4GHz
Gyro: Built-in 6 Axis Gyro
Camera Pixel: 2MP
Charging Time: About 200mins
Flying Time: About 5 - 7mins
Control Distance: About 100m
Copter Battery: 7.4V 2000mA Lipo Battery
Control Battery: 4 x 1.5V AA Battery ( Not Included )
Headless Mode
Barometer Set Height
Camera
LED Light
4gb memory card Included
Required to Fly:
4AA Batteries
