Iron Track Bowie 1:10 Scale 4WD Brushless Truck Ready to Run (Red) RC Remote Control >
Old 04-10-2018, 01:04 PM
Default Iron Track Bowie 1:10 Scale 4WD Brushless Truck Ready to Run (Red) RC Remote Control
https://www.nitrorcx.com/16c553-red-rtr-24g.html
The Iron Track Bowie four wheel drive brushless truck is totally transformed. If you thought the brushed version was fast. This brushless system will make your palms and fingers sweat! Injecting the revolution of electric motor and power systems to this truck results in a 45 amp programmable splash proof electronic speed controller and a torquey 3215kv brushless motor all juiced by a 7.4v 2000mah Lithium Polymer battery with an impressive 30C continuous and 50C burst rating. The Bowie is equipped with all the quality features you would expect from a hobby grade radio control truck. High performance front and rear differentials and an aluminum center drive shaft ensure maximum power transfer and superb reliability from the powerful brushless power system. Adjustable width suspension arms and oil filled shocks provide the plush terrain taming response to allow maximum control during high speeds. The steering servo supports more than 6 pounds of torque to allow precise corning and the ability to hold that drift or line when you’re smashing on that throttle. The 2.4ghz dedicated receiver and transmitter systems allows precise control and tuneability. Throttle and steering dual rates allow you to get comfortable with the increase in power and speed along with throttle and steering trims to get the truck tracking precisely. You can tame a variety of terrain with this truck. The wide all terrain tires allow the rubber to grip at any surface with ease. The pre-cut and pre-painted body allows you to run your truck as soon as you get the battery charged. This extreme Iron Track Bowie is ready for action. Be prepared to be blown away by the speed.
The model comes fully built with everything you need to get going apart from four AA batteries for the transmitter. We have not been this excited about a new model for a long time and you will know why when you hit the throttle for the first time and see it pop a little wheelie before taking off at such a crazy speed.
Bowie Features:
2.4ghz transmitter
Direct axle power transfer
Powerful 540 sized 3215kv Brushless Motor
45A programmable waterproof Brushless ESC
7.4v 2000mah 30C Continuous 50C Burst Li-Po Battery
Pre-Cut Pre-Painted Body
3kg/6.6lbs Steering Servo
Robust Front and Rear differentials
Adjustable Width Suspension Arm
Aluminum Center Transmission Shaft
Specifications:
Length: 422mm
Width: 355mm
Height: 163mm
Wheelbase: 296mm
Required to Run:
Four AA batteries
Li-Po Battery Charger
**Note**
45amp ESC is rated for 4-7s Ni-Mh batteries or 2s Lithium polymer. Using a battery with higher voltage can damage esc or motor.
NitroRCX.com is offline
