Old 01-30-2006, 07:07 AM   #1
Default I hate Centax clutches!!!!
If I ever get this thing put back together correctly, hell might freeze over.
sstupid is offline   Reply With Quote
Old 01-30-2006, 07:56 AM   #2
rccobra705's Avatar
Default Centax clutch
Check out this link:
http://www.mytsn.com/publ/publ.asp?pid=10534&ccid=9
Good look
rccobra705 is offline   Reply With Quote
Old 01-30-2006, 08:35 AM   #3
captian's Avatar
what are you having trouble with?
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 01-30-2006, 08:55 AM   #4
If you have the original clutch as shown on that link, I feel for you man. That Serpent clutch sucks as you have to shim from behind the flywheel to get spacing correct. What a turd that thing is!
birel1 is offline   Reply With Quote
Old 01-30-2006, 11:29 AM   #5
Julius's Avatar
What do you mean with having to shim from behind the flywheel. The only Serpent clutch that needed that was the very first centax (the one everybody else copied afterwards).
The centaxes from 1998 onwards have all been shimmed from the outside.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 01-30-2006, 12:33 PM   #6
that link that rccobra705 gave is great I could never shim correct until that article came out.Its nice to see someone else drive this car,I love it its got the centax II and the two speed that the 1/8 scale serpent cars have.if you need any pointers on this car I would be glad to help,I have had this car since it came out and am still able to keep up with the pack.Keep positive once you get the hang of it everything else will fall into place.Also wanted to thank you for giving me the ebay link for the 705 that was for sale,but the guy didn't want to ship to canada.Someone gave you a link for ashfordhobby,Robert is great A-1 customer service.....ed
fasteddie d is offline   Reply With Quote
Old 01-30-2006, 12:34 PM   #7
rccobra705's Avatar
I make this link to Centax 2 and Centax 3. I have them both. Have never shim Centax 2 and Centax 3 behind the flywheel. The link to Cauleys artikcle explain all you need to know about Centax clutch 2 and 3.
Old 01-31-2006, 12:44 AM   #8
Thanks for the link, man. I think that will help, once I get my new thrust bearing and thrust bearing spacer in the mail. I ordered from Robert at Ashford Hobbies, before. He's a helluva guy, but his parts list doesn't include pics. For a noob, the pics are necessary. I don't have a book for my 705, so I use www.acehardwarehobbies.com. They have pics of almost all the Serpent parts.
The problems I'm having stem from the fact that I bought the car used. The clutch was missing the 0.5 mm shim, behind the flywheel, it had two 5X10 bearings underneath the bell, instead of one 5X10 and one 5X13,it had a thrust bearing that was missing 3 of the 5 balls, and it had no shims in it. Not knowing much about nitro cars or clutches, I ordered a thrust bearing from Robert. Did I order the 5X10? Of course not, I ordered the 5X9mm, because I'm ignorant. I tore it out of the package before finding out it was the wrong one, so I have a useless, shiny, new 5X9mm thrust bearing, if anyone wants it. When I get the new 5X10mm thrust bearing in, (2 weeks later) I notice that the spacer is scored, so I order a new one. When I get that in, I find the tech manual stuff on the Serpent site and what do you know? I need a 5X13mm bearing and a bunch of shims. They are on order, right now. I suppose, once I get it put together correctly, the clutch shoe or the flyweights will be worn and have to be replaced. That's when I will realize I could have just bought the whole setup for $98.
Old 01-31-2006, 12:52 AM   #9
Rapid Roy's Avatar
Man, you need to go to www.mytsn.com and login. The manual is there for you to download as well as lots of great information. Heck, I'll sell you a whole 705 roller for $150+ shipping.
Rapid Roy is offline   Reply With Quote
Old 01-31-2006, 07:15 AM   #10
Does it come with a fully-operational clutch?
Old 01-31-2006, 09:26 AM   #11
GUINT1's Avatar
The centax clutch
is not that hard to set up
just follow the instruction above.
Empire Racing/Maxy's fuel/Ko Propo
Motor. .21 FLASH/353 Race
Body. Zytech/P909
Tyres. Ky Red Box
GUINT1 is offline   Reply With Quote
Old 01-31-2006, 09:54 AM   #12
Rapid Roy's Avatar
Yup!!
Old 01-31-2006, 01:38 PM   #13
Xyvern's Avatar
The kit for Serpent 710 cames with Centax 2 or 3
Xyvern is offline   Reply With Quote
Old 01-31-2006, 01:55 PM   #14
Rapid Roy's Avatar
710 comes with the "3"
Old 04-25-2006, 02:09 PM   #15
TRFTIM's Avatar
Ive understood all that but it seems that i need a hell of alot of shims in order to get 0.6mm almost 1mm
When i put the 1MM shim on the thrust bearing spindle and install the bearings into the clutch housing and tighten everything up, the cluch is engaged !!!!!
Any ideas as its starting to really me off .
TRFTIM is offline   Reply With Quote
I hate to say this but.... GundamWZero Chat Lounge 20 07-09-2008 01:56 PM
I hate to do this but it all needs to go tlxxx4driver R/C Items: For Sale/Trade 8 12-09-2007 09:30 AM
I HATE YOU! Team Ash Australia For Sale/Trade 12 07-18-2007 02:38 AM
2 RB .12 modified Engines (SG Shaft),4 Tuned Pipes, 2 Centax Clutches ClubRacer R/C Items: For Sale/Trade 18 07-05-2004 11:42 PM
