Old 02-18-2007, 06:25 PM   #91
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
Originally Posted by rollover
Since mytsn.com has updated I cannot seem to get to the centax articles. Is it me or is there a secret way to get to them?
Hi Tom,
Yes, in the initial reformatting of the site, they did remove all my articles. However, they said that moving forward they would be selectively re-introducing some of them. Mine should be back, but it's just a question of when.
Glenn
Originally Posted by Tire Chunker
Glenn,
Did MYTSN jank the articles? I thought they would at least keep links to the great info of the old site. I run Mugens but was impressed with the info of the writers.
I have only raced on-road nitro a couple years and after reading your centax clutch articles the new guy has helped out some long time racers het the balky clutches running better.
Tom
Glenn Cauley
Ottawa, Canada
Tire Chunker is offline   Reply With Quote
Old 02-18-2007, 06:25 PM   #92
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
that is true....since the update,there is no more profile page,or any of the old tech articles...shame..
this might help you...
http://www.rctek.com/info_centax_clutch.html
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 06-16-2007, 09:43 PM   #93
gearhead13's Avatar
I have had my Serpent 710/centax for a couple months now and have blown two thrust bearings. The last one only lasted 2 weekends. I regrease it after every race. I put in .35 mm shims for proper endplay of bearings. I have .5 to .6 of clutch gap.
What is so great about centax??? because its adjustable? I have to tear it apart so often to maintain it I might as well be cutting down clutch shoes while im at it.
gearhead13 is offline   Reply With Quote
Old 06-16-2007, 11:30 PM   #94
Simon M's Avatar
What type of grease are you using?
I use mugen super grease which is realy tacky and thick keeps the thrust bearing lubed from half an hour to an hour
You could also try the new ceramic thrust bearing
http://rc-mushroom.com/product_info....oducts_id=3932
http://rc-mushroom.com/product_info....oducts_id=3885
Serpent 960
Serpent 720
Serpent S400
Serpent S120
Tamiya M03-R
www.serpentradiocontrolcars.com.au
www.smaracing.org
Simon M is offline   Reply With Quote
Old 06-16-2007, 11:36 PM   #95
Simon M's Avatar
And give this article a read from serpent about Building the Perfect Centax-3 Clutch
http://www.serpent.com/news/10063/Bu...-3-Clutch.html
Serpent 960
Serpent 720
Serpent S400
Serpent S120
Tamiya M03-R
www.smaracing.org
Old 06-17-2007, 10:34 PM   #96
gearhead13's Avatar
I talked to a couple of local racers today, our regular race day and they have their centax set up with VERY little clutch gap and havent blown a thrust bearing in a year. So, I set it up that way, it ran fine, I just had to tighten up the adjusting spring for a better engagment point. Before, I had the adjusting spring collar backed all the way off.
Old 06-18-2007, 01:12 AM   #97
razzor's Avatar
ive noticed that some guys run a bit excessive endplay and this is a cause of thrust bearing failure as it shocks the bearing and puts them under more uneccesary load.I am running 2 clutch sets on two engines i use in mt G4S and the ones has well over year of use with track days, nationals and practice days under its belt and thrust is still smooth.
I run .1mm endplay with no hassles also i use FinishLine Dupont teflon grease for bicycles.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-18-2007, 02:44 AM   #98
rcabj's Avatar
well my thrust bearing last at least a year...i race 7/8 times year round
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 06-18-2007, 09:55 AM   #99
Here's .02 cents worth....
Compare the diameter of the thrust bearing balls on the Serpent thrust bearing and the Mugen thrust bearing. The Mugens are larger which means that bearing runs at a slower speed. Less speed = Less heat.
Also, try Dupont Krytox Grease in the thrust bearing...whichever you decide to use.
b_esser is offline   Reply With Quote
I hate to say this but.... GundamWZero Chat Lounge 20 07-09-2008 01:56 PM
I hate to do this but it all needs to go tlxxx4driver R/C Items: For Sale/Trade 8 12-09-2007 09:30 AM
I HATE YOU! Team Ash Australia For Sale/Trade 12 07-18-2007 02:38 AM
2 RB .12 modified Engines (SG Shaft),4 Tuned Pipes, 2 Centax Clutches ClubRacer R/C Items: For Sale/Trade 18 07-05-2004 11:42 PM
