Old 01-29-2006, 02:27 AM   #1
BrainTeased's Avatar
Default Clutch adjustments for fuel mileage
Hi guys could someone please tell me which adjustment on centax clutches would extend fuel mileage / runtime, and decrease operating tempreture
A more agressive setting
or
A more smooth clutch setting
thanks guys
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 01-29-2006, 02:42 AM   #2
AndyT 's Avatar
To help improve runtimes a clutch setting that engages at lower rpm will help give you better economy......this way youre not using "x" amount of rpm (and fuel) in getting the clutch to engage at a higher rpm.
Cheers
AndyT  is offline   Reply With Quote
Old 01-29-2006, 05:50 AM   #3
thanks Andy
will that also lower the operating temps compared to a aggresive punchy setting?
Old 01-29-2006, 02:46 PM   #4
AndyT 's Avatar
I`d hazard a guess and say yes (because the engine wont constantly be working in a high rpm range), but it would also depend on other factors such as air flow thru the car body, tune etc
Cheers
Old 01-29-2006, 04:16 PM   #5
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Ok. I have to disagree with Andy on this one. I initally thought this to be true, but now I have the opposite theory with the clutch. I have found when I set the clutch to engage earlier (at lower RPM) the car has less punch coming out of the turns. Because of this, I not only get into the throttle earlier, but I pull the trigger harder. I end up using more fuel with it set that way. I find the the gearing and shift point to be able to make a bigger difference in fuel economy. Taller gearing and an earlier shift point can save some fuel. I think the best adjustment you can make to save fuel is the way you drive the car. I think smooth throttle control and smooth driving will save more gas than any adjustments to the clutch and transmission.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-01-2006, 05:02 AM   #6
thanks guys for your input ill try do both smooth setting and smooth driving
BEST FUEL MILEAGE PIPE ???? dead1dave Nitro Off-Road 12 08-25-2008 06:04 AM
1/8th scale Fuel Mileage Thread Scootersisters Nitro Off-Road 8 10-07-2007 07:27 PM
Fuel Mileage blues? rltanner Nitro Off-Road 33 09-25-2007 01:36 AM
Best fuel mileage .21? 22Racer Electric Off-Road 13 01-29-2007 09:10 PM
Poor fuel mileage Jasonsuper50 Electric Off-Road 17 06-28-2006 08:42 AM
