Protoform R19 1/8 body >
Like Tree18Likes
Old 08-19-2017, 06:49 PM
  #16
mustangkillaz's Avatar
Glad you guys are running this, I'm just trying to finish mine. I put the front wheelwell in line with axle.
mustangkillaz is offline
Old 08-20-2017, 03:39 PM
  #17
Are you guys using included stiffeners?
If so, any pics and are you guys using all of them?
Old 08-20-2017, 07:44 PM
  #18
Cant drive's Avatar
Stock stiffiners can definitely be used. Cut them so you have 6 total stiffiners place them just behind front wheel, in front of rear wheel and behind rear wheel. If you use the stock screws just know that they use a 1/16 head not a 1.5mm. Alternatively, you can use double sided servo tape if you don't want to use the screws but I like the security the screws provide.
Cant drive is offline
Old 08-20-2017, 08:16 PM
  #19
Gotcha. Screws could be ugly. I'm gonna see if 3m uhb will do. I see two larger supports and 4 smaller. Where do the larger ones go?
Old 08-21-2017, 12:07 AM
  #20
Cant drive's Avatar
Large ones go behind the rear wheel where you need the extra support.
Old 08-21-2017, 01:05 AM
  #21
Cool thanks.
Old 08-21-2017, 11:28 AM
  #22
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
Double sided tape is not enough. First time I tried this and after one practice session, 8 minutes, I had 1 left.
GrandeGixxer is offline
Old 08-21-2017, 12:36 PM
  #23
It should be enough, I'm using automotive permanent grade 3m tape. What did you use?
Old 08-21-2017, 03:38 PM
  #24
Black servo tape. Cleaned everything with rubbing alcohol first.
Old 08-21-2017, 04:01 PM
  #25
Cool.
There a few grades of servo tape, I use the 3m uhb on high heat and difficult areas; let's hope it holds.
I'm waiting for paint to dry to continue the process. I've got a few coats and colors left. I tried rushing, but masking was coming off like shit, so I just slowed down. I learned a lot, my next body will be nicer for sure.
Old 08-21-2017, 04:04 PM
  #26
Here is the progress.. far from done. I hope I like the end result.
Attached Thumbnails Protoform R19 1/8 body-15033565944171168109720.jpg
Old 08-22-2017, 04:16 AM
  #27
A lot of guys use pop rivets for the stiffeners as well. They make some plastic ones or you can use the small aluminum ones.
Old 08-22-2017, 08:05 AM
  #28
dan_vector's Avatar
Trader Rating: 27 (100%+)
I use the plastic pop rivets from Xceed to secure my body stiffeners. Works very well.
Serpent-Dan and desotoracing like this.
dan_vector is offline
Old 08-22-2017, 03:11 PM
  #29
LOW ET's Avatar
Trader Rating: 103 (100%+)
part # or link?
never mind, i found them on serpent america's site.
LOW ET is online now
Old 08-22-2017, 04:26 PM
  #30
Almost done with my body. Two more colors and a backer are all that's left.
Attached Thumbnails Protoform R19 1/8 body-20170822_162054.jpg
