Old 01-22-2006, 02:04 PM   #1
Default Stinger...
I am sure I'm not the first to do this....
I bent the stinger on my Skyline VR12 exhaust...I took a pair of plyers and bent it back, but it left a small "dent" around the base where the stinger and pipe meet.
My Question is: Does this affect the performance of the pipe? If so, how and how much? Also, I have seen folks use some sort of compound to apply around the base of the stinger to reinforce it. What is this compound?
Thanks!
MikeyG is offline   Reply With Quote
Old 01-22-2006, 04:52 PM   #2
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
You can use JB Weld around the base of it to strenghen it. I have a Snap On phillips screwdriver that fits perfectly in the stinger to bend them back. the little dents wont affect it very much at all. It is the larger dents that change the volume of the pipe a lot that will make a noticeable difference.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 01-22-2006, 05:57 PM   #3
Chris West's Avatar
Send a message via MSN to Chris West
you could get it welded like my one. its almost 2 years old and hasn't bent or anything. have a look
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 01-22-2006, 06:08 PM   #4
Rapid Roy's Avatar
I have used somthing called "quick steel". You can get it from any automotive store. Its a 2 part clay. When you kneed it, the 2 compounds mix. You just mold it around your stinger and wait. It cures in a few hours. I have an old nova pipe fixed up like that. Not much to look at, but it works really well.
Rapid Roy is offline   Reply With Quote
Old 01-22-2006, 06:08 PM   #5
AndyT 's Avatar
Theres also a product out called Quiksteel......its probably much the same as JB Weld i guess.
You just take it from the pack, knead the amount you require until it starts to get warm, the apply it to the pipe.....sets like steel. Its available here from the auto section of most larger variety/retail stores.
Cheers
PS.....if the pipe body is dented inwards, you can always use the freezer technique to get the bumps out.....fill the pipe with water after sealing the stinger (i use cling wrap), and pressure fitting (i use kinked fuel tubing), then fill with water and put in freezer......check every 15 minutes till the bump is frozen out.
AndyT  is offline   Reply With Quote
Old 01-22-2006, 06:18 PM   #6
Rapid Roy's Avatar
Pretty funny. You must have posted a split second after me. The post times are the same.
Old 01-22-2006, 06:53 PM   #7
That's great info guys...I picked up some quicksteel! I will try the freezer method on one of my old pipes...sounds interesting.
Thanks!
Mike
Old 01-23-2006, 03:17 AM   #8
RayJ's Avatar
Default Freezer technique
Sometimes it takes a couple of times in the freezer to get dents out. One thing I've done that seems to work is to wrap the the undamaged portions of the pipe tightly with battery strapping tape. This focus's the expansion at the dent, and will control the "overexpansion" of the portion of the pipe that is okay.
RayJ is offline   Reply With Quote
Old 01-23-2006, 03:35 PM   #9
AndyT 's Avatar
Certainly was close timing
Cheers
Old 01-27-2006, 05:50 PM   #10
Location: Sydney, Australia Home for none of you rc needs!
haha ive never seen that done before...good timing guys haha
chrisanton is offline   Reply With Quote
Old 01-28-2006, 09:24 AM   #11
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Quick steels works great you can't wrong.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
xl-5 + stinger motor murder R/C Items: For Sale/Trade 9 05-08-2008 01:12 AM
Vintage Car Help (Stinger) Chris P Rookie Zone 0 05-02-2007 09:28 AM
MIP Stinger Exhaust?? six60grizzly Electric Off-Road 0 03-10-2003 08:15 AM
Stinger alterations Kboejoe Monster Trucks 5 02-22-2003 05:12 AM
Stinger broke.... new92 Nitro On-Road 7 01-10-2003 10:36 AM
