Kyosho Inferno GT3 (MP9 TK14) >
Like Tree29Likes
Old 06-30-2019, 12:01 PM
  #136
mustangkillaz's Avatar
Originally Posted by MikaR View Post
I believe diffs come loose after a short break in (one tank)
binding can be relieved by pressing around the link balls with pliers. not sure if there's like any other way. in my mp9 I havent noticed binding.
Yea, some running always loosens diffs up. Was just kind of concerned because these were more crunchy than all the other cars I've built.
Molested the living daylights out of the binding ends and they are 70% there.
Building the clutch now, Novarossi take the 2 shims shown in the illustration? Can't find my flywheel puller and wanna get it right first time.
mustangkillaz is offline
Old 07-06-2019, 02:27 AM
  #137
My car is basically done. Finishing up the body.
Reading up on option parts. Wondering which ones are a must.
MikaR and I_NeedBigDrink like this.
Old 07-06-2019, 11:56 PM
  #138
MikaR's Avatar
without having driven this car I would say the only thing are the 4deg caster blocks
MikaR is offline
Old 07-08-2019, 12:30 AM
  #139
Yea, kyosho mentioned those. I haven't driven it yet either. Trying to get the larger pinion issue resolved. The evolva bell and gears are off center, I'll have to play with shimming the gears and/or whole assembly. Looks like the serpent bell and pinions might be the better choice. Xray has some offerings as well. Looks like some more digging will be needed.
I picked up another body, will work on that this week, too. Not happy the way this one turned out, I'll likely dump it.
Old 07-08-2019, 02:55 PM
  #140
MikaR's Avatar
sorry to hear about the clutch bell and evolva gears. is it the FW05 bell like discussed earlier?
I might be getting this car, too
MikaR is offline
Old 07-08-2019, 08:35 PM
  #141
PN ending VS058.
Here is a pic of another clutch bell, it's short as well.
Old 07-09-2019, 08:06 AM
  #142
MikaR's Avatar
right, I see. it does not look so bad but maybe a bit off. I think we used some shims behind the pinion 2nd gear.
MikaR is offline
Old 07-09-2019, 08:47 AM
  #143
assembly is the gt3 clutch. Still needs some adjustment
Old 07-14-2019, 12:43 AM
  #144
Break in pretty much done. Tune time later today. Wonder if a GT/Rally motor is more suited to this car over the current on-road one. Started a new body for it as well.
Old 07-15-2019, 11:48 AM
  #145
MikaR's Avatar
Looks good! Yeah rally cross / offroad motors are better suited since using an offroad clutch and the car is heavier with rubber tires, I think. I hope you're using an air filter though not pictured
MikaR is offline
Old 07-15-2019, 12:07 PM
  #146
My buddy is gonna give me a dedicated GT engine. I've got a Capricorn 803 that I'll likely put this motor on. Wonder if the GT motor will turn anywhere near the rpm that this current motor turns. It's on foam tires at the moment.
I don't always run filter on break in if the environment is clean. It's on there now. Looks like there is a hold down provision that isn't listed in the GT3 manual.
MikaR likes this.
Old 07-21-2019, 09:12 PM
  #147
Anyone try the gt2 3d front bumper? Bolt in? Didn't look like at first glance. My body has a touch of flop up front.
