Like Tree13Likes
XRay GTX8
Old 06-28-2017, 03:08 PM
  #31
KR145's Avatar
Maiden voyage on the radar
petersen114, T-Hawk and fergraz like this.
KR145 is offline
Old 06-28-2017, 03:20 PM
  #32
scary_jerry's Avatar
Default 😜
We're anxiously looking forward to your first impressions!!! 😎
Any insights into the 'mysterious CASTER angle'.....????
scary_jerry is offline
Old 07-07-2017, 01:49 PM
  #33
Trader Rating: 42 (98%+)
Here is the caster setup section for the GTX8
wichitafc98 is offline
Old 07-18-2017, 12:03 AM
  #34
Got my car all finished and had it all run in.
Nice car to build as xray always are.
A bit of a question when doing the set-up do you have the car on the chassis on a flat bench to do the droop.
As I tried to do it like my touring car and f1 with 10mm blocks but can not figure it out.
It does say to measure from under the threaded part of the hub.
I do have the droop gauge it says in the book.
Can anyone point me in the right direction.
Kinder is offline
Old 07-18-2017, 07:19 AM
  #35
KR145's Avatar
I am no expert, but I just use the 20mm blocks and gauge.
KR145 is offline
Old 07-18-2017, 08:03 AM
  #36
Scott B's Avatar
Trader Rating: 45 (100%+)
Most GT8 droop setups are done with the chassis on the setup board no blocks and then measured to the bottom of the wheel hex. Those would be the 23-27mm settings you read on a setup sheet. You can still use blocks if you want you just need a third block to go under your droop gauge so it's at the same height as the chassis.
Flo-control makes these nice blocks for measuring droop on gt8's that work awesome. . Well they did I can't find them on there site.
Scott B is offline
Old 07-18-2017, 11:30 PM
  #37
Ok thanks for the advice on the use of the droop gauge.
The factory set-up says 0 for front and -11 for the rear.
It seems like a lot for the rear.
I run on a large open low grip bumpy track.
We are currently in the middle of our winter in NZ.
Any advice?
Kinder is offline
Old 09-14-2017, 05:38 PM
  #38
Default What clutch / clutch prings is everyone using
Hi all
Just building the kit and was looking at what is the best "clutch configuration" to use.
Are the Xray "hard" springs better and what shoes are you using
Ta
Jeremy
JSimons is offline
Old 09-15-2017, 07:56 PM
  #39
Default Xray xb8 15 conversion
Hello i am new to on road but have off road for 15 years. I have a 2015 xb8 that i would lime to convert if possible to the gtx8. Could any of you experienced gtx8 racers inform me if its possible and also cost efficient to convert? Thanks your help is greatly appreciated.
turbo06 is offline
Old 09-18-2017, 12:24 AM
  #40
wkloppen's Avatar
Attachment 1434175
Im seriously contemplating of buying this kit this winter but with 22 degrees of mininum caster??...Do I interpret that correctly?....seems a lot.
By the way: are these caster numbers the total caster including the kickup?
regards
Willem
wkloppen is offline
Old 10-05-2017, 11:57 AM
  #41
Default Aftermarket clutches - are they any better for GT on road?
Hi all
Just looking at after market clutches, BUKU, REDS etc.... is anyone using these on the Xray?
Firstly do they work , make a difference on onroad cars?
What modifications are needed if any?
If not what is the best combination of springs, shoes to use for good punch
Jeremy
JSimons is offline
Old 10-05-2017, 12:05 PM
  #42
KR145's Avatar
We been running Buku up here in the great NorthWest with great success and longevity.... Make sure to use a new clutch bell if you use the buku..used one will contaminate the ceramic shoes.
KR145 is offline
Old 10-08-2017, 12:11 PM
  #43
Default Buku Clutch
Thanks Kevin
Can you confirm what flywheel diameter you are using and also what clutch shoes, standard or lightweight??
Part no's??
Also where is the best place to purchase these clutches with good postal rates
Ta
Jeremy
JSimons is offline
Old 10-08-2017, 08:01 PM
  #44
T-Hawk's Avatar
Originally Posted by JSimons View Post
Thanks Kevin
Part no's??
Ta
Jeremy
32 mm flywheel, lightweight Komp shoes, GT springs
T-Hawk is offline
Old 10-09-2017, 05:08 PM
  #45
Thanks Ryan
Where do you get your clutches from??
I'm in New Zealand so looking for good postage rates if possible
Ta
Jeremy
JSimons is offline
