Allen Wrench in electrics screwdriver ?
Hi guys,
I usually use this screwdriver for phillips screws, but now im changing to all ALLEN TYPE ... http://www.blackanddecker.com/Produc...ProductID=5483 Do you know if exist some kit with good quality metric allen to fit on this kind of electric screwdrivers ? thanks, |
if your power tool use a stand 1/4" socket, then you might want to check this out. they make decent bits and i think they guarantee their porducts for life. you might want to get an extension becasue these bits are kind of short. i saw a set somewhere that has longer bits, will let you know if i found it. |
ofna makes allen keys the slide into your mini drills with the hex holder on it
Get the ones from Ofna they are awesome. Mine are 3 years old and work incredibly well.
http://www.ofna.com/images/tool-bit-93129.jpg |
http://www.ofna.com/images/tool-bit-93129.jpg Wow, i will try to find those ... every bit i just tested its low low quality on our hobby-allen-screws ... all ended rounded ... |
Hi guys,
I usually use this screwdriver for phillips screws, but now im changing to all ALLEN TYPE ... http://www.blackanddecker.com/Produc...ProductID=5483 Do you know if exist some kit with good quality metric allen to fit on this kind of electric screwdrivers ? thanks, I don’t know if they shipped outside the U.S. but try them out. They carry hex screwdriver bit for power drives. Click on this. |
i use the ofna allen wrenches in the panasonic screw driver. This driver is the best i've ever used, with a electric clutch and a quick battery charger.
