Capricorn C803 1/8 On-road >
Like Tree34Likes
Old 07-31-2019, 01:20 PM
  #106
mustangkillaz's Avatar
Originally Posted by LOW ET
why is it easier to work on?
less clutter and radio tray layout is more friendly.
mustangkillaz is offline
Old 04-24-2020, 10:30 AM
  #107
Default New Capricorn Owner
Hi guys,
I am a new proud owner of the C803, i am wonder which shore tire to use. The track is asphalt with high traction (old car park), i currently have 35 to front and 37 to rear. Any advice?
Tallman1989 is offline
Old 04-24-2020, 03:04 PM
  #108
Originally Posted by Tallman1989
Hi guys,
How does the car feel? Loose? Lower shore in the rear, vice versa if its too stuck
Giant655 is offline
Old 04-24-2020, 03:11 PM
  #109
YoDog's Avatar
Trader Rating: 28 (100%+)
Hi guys,
That's a really common combination. You can use those to establish a good baseline setup and then determine a tire change depending on track conditions. Warmer weather on a large-ish track with high traction, you can easily go 37f/37r or 37f/40r depending on front end bite and tire wear. Don't forget to use a 7mm tire split.
YoDog is offline
Old 04-25-2020, 01:21 PM
  #110
Can you explain the 7mm tires split
Old 04-25-2020, 01:25 PM
  #111
i havent driven it as yet...... i am waiting on the engine (O.S 2103)
Old 04-25-2020, 01:53 PM
  #112
YoDog's Avatar
No worries...
it's a 7mm difference in tire diameter from front to rear. Let's say that the rears are 75mm diameter, the fronts should be 68mm to start. it makes a big difference under acceleration. If the fronts are too small compared to the rears the car will tend to over rotate on power and will feel like the front belt is stripped.
YoDog is offline
Old 04-25-2020, 02:26 PM
  #113
Originally Posted by YoDog
No worries...
Ahh...understood....is there a site i can get tires and spares at a reasonable price ?
Old 04-25-2020, 02:33 PM
  #114
Trader Rating: 83 (100%+)
RC Target for parts and tires
martind1318 is offline
Old 04-25-2020, 02:35 PM
  #115
thank you.....i recently bought a O.S 2103 .21 engine. How good is that engine ?
Old 04-25-2020, 06:13 PM
  #116
YoDog's Avatar
It's a good engine. I have one too.
It's my first OS as I have run Novarossi for years So far I like it. Did you get the combo?
You might still be able to get Hot Race tires at a great price from Wallace Motorsport. Right now they are looking like $32 per set.
YoDog is offline
Old 04-26-2020, 03:38 AM
  #117
Yes i got the combo...... Thanks again for your response. ...... I will check wallace motorsports for the tires. I want to get a spare engne as well but less expensive. Any suggestions
Old 04-26-2020, 07:56 AM
  #118
YoDog's Avatar
Check out Novarossi Direct, they have some good deals.
FLASH .21 PT/S
You really can't beat this one for the money. It even has ceramic bearings.
LEGEND 7ON
I'm gonna pick up a couple of these and do some small modifications to them.
https://wallacemotorsports.net/ielas...tuned-pre-run/
Badass motor fro under $400.
YoDog is offline
Old 04-27-2020, 04:58 AM
  #119
is it possible for me to buy parts to modify my O.S 2103 ? If so, where can i get these parts?
Old 04-27-2020, 09:06 AM
  #120
YoDog's Avatar
RC Target does carry replacement piston and sleeve sets which are from modified engines they sell. I believe the Max RP9 is OS based. I could be wrong but you can likely buy replacement modded parts from various tuners that use OS based engines like Rody VS.
YoDog is offline
