Capricorn C803 1/8 On-road >
Like Tree33Likes
Old 01-26-2018, 10:21 PM
  #46
Is another term for the F1 bar the blade style?
Why did everyone make the switch to bars instead of blade anyway?
Giant655 is offline
Old 01-27-2018, 07:32 AM
  #47
Originally Posted by P2gee View Post
While some people don't like them, I prefer the F1 bars and use them front and rear. I have a selection of rear bar sizes I ordered from capricornrc.com in Italy. Mind you, shipping is a little pricey ordering from them. Rctarget can order just about anything you want from Capricorn so you might give them a call and see what they can do for you.
Yes, I love. Normally I have 2 bars on each end, front 1.3 and 1.2, rear 2.7 and 2.5mm.
beebone is offline
Old 01-27-2018, 01:59 PM
  #48
snuvet75's Avatar
Trader Rating: 16 (94%+)
F1 bar is blade in the middle
snuvet75 is offline
Old 01-28-2018, 12:47 PM
  #49
Default weigths
Are people running brass weights on their chassi? Itís an evo chassi.
Houmb is offline
Old 01-29-2018, 06:45 AM
  #50
P2gee's Avatar
Originally Posted by snuvet75 View Post
I like the front F1 bar I have too. I don't see why some don't like it? Well aside from being pricey. Why do you like it if I may ask?
One of the things I like about them is the ease of changing bars if your at the track. Another thing is its pretty easy to modify the bars by by reducing flat section thickness or length and/or flat section width to come up with custom bars for your application.
snuvet75 likes this.
P2gee is offline
Old 01-30-2018, 06:17 AM
  #51
Yes I do!
This car is under-weight, the side 16g brass won't affect the handling, only add the 15g brass cylinder if you need more oversteer. I also run with the 26g brass battery plate as well.
Houmb likes this.
beebone is offline
Old 02-01-2018, 01:28 AM
  #52
Do you use the set screw in the gearbox shoes? Just finished the build, and it rub's to much against the bell..
Houmb is offline
Old 02-01-2018, 03:33 PM
  #53
snuvet75's Avatar
Are you talking about 2 speed shoes rubbing against drum? If you use set screws, it will spread them apart even more. If there's visible gap between the 2 shoes, you can turn out the set screws (if installed) to close the gap.
snuvet75 is offline
Old 02-01-2018, 04:24 PM
  #54
Trader Rating: 82 (100%+)
I use 2mm or 2.5mm long set screws
Nitro-mech is offline
Old 02-01-2018, 10:36 PM
  #55
Yes, 2speed shoes, rubbing against the drum. Took them out, and it's smooth.
Houmb is offline
Old 02-01-2018, 11:54 PM
  #56
snuvet75's Avatar
Since the shoes are new, it should be fine w/o set screws. Later, you can put them back on.
snuvet75 is offline
Old 02-02-2018, 08:29 AM
  #57
Yes, the 3x3mm set screw will rub the bell. I'm using Mugen 3X2.6mm set screw instead
beebone is offline
Old 02-02-2018, 09:19 AM
  #58
Thank you guys..
Any good starting point on the springload, for the 2 speed?
Houmb is offline
Old 02-03-2018, 06:42 PM
  #59
bypass911's Avatar
Trader Rating: 14 (100%+)
Very dumb question but can I run GT style clutches instead of centax? Sorry, complete noob at this.
bypass911 is offline
Old 02-03-2018, 09:23 PM
  #60
snuvet75's Avatar
Thank you guys..
Follow manual's instruction first. Then adjust for your track. The smaller the track, the quicker 2nd speed should kick in as you may already know.
snuvet75 is offline
