Capricorn C803 1/8 On-road >
Like Tree33Likes
Old 05-05-2020, 05:52 AM
  #136
dan_vector's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Tallman1989 View Post
any advice on how to power my hudy starter box ?
3s or 4s lipo
dan_vector is offline
Old 05-06-2020, 08:57 AM
  #137
YoDog's Avatar
Trader Rating: 28 (100%+)
Tallman...A side note regarding the use of a LiPO in a starter box, tire truer, etc. Never let the battery run low as it will ruin the battery. It's really easy to forget and wait till it stops working and if that happens, it's too late. Try to make sure it has at least a storage charge when not in use and check the voltage regularly. You should be fine if you charge before you head to the track. Same goes for all LiPo and LiFe batteries. There are low voltage alarms in the market that plug into the balance port and will make noise when the battery gets low. Well worth the few bucks.
dan_vector likes this.
YoDog is offline
Old 05-07-2020, 10:01 AM
  #138
dan_vector's Avatar
Good idea.... I forget that sometimes!
Old 05-12-2020, 05:41 AM
  #139
thanks for the sound advice.. i will take special note of that. I am also looking for bodies at a reasonable price. any suggestions?
Tallman1989 is offline
Old 05-12-2020, 12:24 PM
  #140
YoDog's Avatar
Get the precut for Capricorn "Diablo" by Xtreme Aerodynamics from RC Target It will save you time and the price isn't too bad. Also order the stiffener kit. This adds an additional $20 but well worth the price as they are purpose fit for the Xtreme bodies.
YoDog is offline
Old 05-12-2020, 04:20 PM
  #141
ok thank you...i already have some stiffners on my current body so can reuse them.
Old 05-12-2020, 08:42 PM
  #142
YoDog's Avatar
Sure but if you look at the Xtreme stiffeners, you will see how they are engineered to work with their bodies.They are precision fitted and come with little rivets that hold them to the body. I prefer to use Shoo Goo but to each his own.
davidl likes this.
YoDog is offline
Old 05-13-2020, 06:13 AM
  #143
i normally use shoo goo as well...used it on my 1/10 electric along with some dry wall tape....it actually work pretty well.
Old 05-21-2020, 07:34 AM
  #144
looking for a good setup station...iis this one good or recommended?
https://www.ebay.com/itm/3RACING-ST-...8AAOSwO~VaglWQ
Old 05-22-2020, 12:07 PM
  #145
dan_vector's Avatar
Itíll probably do the job but Iím not a fan of 3Racing stuff. You would be better off investing in either a arrowmax or HUDY in my opinion. Yes more expensive but will last you a lifetime.
Old 05-22-2020, 12:50 PM
  #146
YoDog's Avatar
+1 on the Arrowmax and would also suggest the Tesla from RC Target. The measurement plate is cut to clear the rear body mount. This is the one I own.
YoDog is offline
Old 05-22-2020, 04:41 PM
  #147
thanks alot for your suggestions...yes hudy is pricey but they make very good products.....i will consider
Old 05-25-2020, 05:57 AM
  #148
good day, i also have the switch that goes from the receiver to the battery pack. Any suggestions on where i can mount this switch in a safe position ?
Old 05-25-2020, 09:00 AM
  #149
dan_vector's Avatar
Don't use a switch, very few people use a switch on a race car (that's why there isn't anywhere to mount one!). You should use a servo extension wire and mount it where there is a provision on the car receiver box and connect the battery directly using the extension as the 'switch'.
Old 05-26-2020, 03:51 PM
  #150
I have a hudy starter box....do i need to adjust the wheel in order to start my car?
