Shepherd Velox V10 "WC" >
Like Tree3Likes
Old 10-15-2018, 09:31 AM
  #31
Just in time for the upcoming World Championship 1/10 on-road in Miami we are happy to release the upgrade set ‘Velox V10 nineteen’.
The set contains new rear lower wishbones, new hinge pin brackets as well as a new rear upper arm mount.
The updated hinge pin position makes the Velox V10 turn faster into corners without loosing traction while a higher overall cornering speed is achived.
The hinge pin brackets are made of high quality 7075 T6 aluminium with blue or black anodizing finish while the upper arm mount his milled from high-quality carbon fibre material.The lower wishbones have been completly redesigned to fit the updated geometry and are injected with premium composite material. They are also available as a hard version with additional glas fibre to better suit hot conditions.The set [500006] and all parts are now available.
As you are used to from us, all parts can also be converted to your 'older' Velox V10 plattform.
Red RC ? RC Car News Shepherd Velox V10 Nineteen upgrade set
QuiXoTic_NL likes this.
thilo-alexander is offline
Old 12-12-2018, 06:25 AM
  #32
We have updated our setup sheet for the
Shepherd Velox V10 'nineteen'.
Edit, save and share your setups using Adobe Acrobat on Windows, iOS, Android or iPhone.
You can download it here:
www.team-shepherd.com/pdf/Setup_V10_2018_edit.pdf
