Mrx5, Nova .21/S Virtus help with end play >
Like Tree1Likes
  • 1 Post By 1/8 IC Fan
Old 02-26-2017, 05:39 AM
Smile Mrx5, Nova .21/S Virtus help with end play
Hi
Just getting some help with my Novarossi engine for my Mugen Mrx5. I done the clutch gap (0.6-0.7). I clutch spring and nut are good but the shims that come in the kit are mostly 0.2 and i put 3 before the big bearing and two between the two bearings, and there still seems to be a fare bit of end play.... Def not 0.1 - 0.2. I have located 0.5 shims. I am just wondering should i put a shim before the flywheel?? Should you only put 3 shims max before the big bearing??
The engine is a Nova Virtus .21/S 3.5cc
Nitromad1020 is offline
Old 02-26-2017, 06:38 AM
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
I have always shimmed before the inner bearing on the clutch bell. There are shim kits available seperatly as well. Shimming before the flywheel collet (cone) is helpful when fine aligning the flywheel location.
Here is a video that may offer some help.
https://m.youtube.com/watch?v=7wjogF57xpo
Michael has a.lot of such videos, that may help and offer some help.
Nitromad1020 likes this.
1/8 IC Fan is offline
