Old 01-14-2006, 07:34 PM   #1
SSmoked's Avatar
Send a message via MSN to SSmoked
Default Strange, someone else take a crack at this
i have a 4-tec. i have had so many probles with it. i ran one motor in a different car, and it was tuned in. but it will barly run when its in my 4-tec. all the berings are good, belts are a little loose, and it seems like its binding some where.
i rebuilt it twice, and its the same. i will try to rebuild the trans and see if it is better. i had it for about 4 months, and it started doing this. and it sat for about a year ever sence then.
any one got any ideas. he could really use some help.
SSmoked is offline   Reply With Quote
Old 01-15-2006, 12:01 AM   #2
Corse-R's Avatar
Remove center belt and check if all two transmissions are free of binding points, if not, cleanup all the bearings with some fluid (soak them in denatured alcohol for 1 hour, dry them and apply a little of a quality bearing oil (serpent is good). If any bearing feels gritty, discard it and change it for a new bearing.
If stills doesn't go fine, try swapping the belts of a brand new set and see if it helps. Check the pulleys and every other rotating part for binding points.
Some cars doesn't go as free as they should, probably your car is one of those.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-15-2006, 12:50 AM   #3
SSmoked's Avatar
well first off its not my car, its just a guy that asked me for help. he said all his bearings are good, and the tranny is good too. his hobby shop rebuilt the car for him and it still does it.
Old 01-15-2006, 01:27 AM   #4
Rapid Roy's Avatar
He just needs to isolate the problem. Since he has already ruled out the engine, go on from there. Does the car roll freeley when pushed?
Is his problem that the motor doesn't seem to run well in the 4tec?
It would really help if he could be as specific as possible when he describes the problem.
Rapid Roy is offline   Reply With Quote
Old 01-15-2006, 09:31 AM   #5
Dreddlox's Avatar
Did you check the clutch assembly? If thats not right you will definately get that problem.
Dreddlox is offline   Reply With Quote
Old 01-15-2006, 09:48 AM   #6
T. Thomas's Avatar
Also, are the clutchbell or other items rubbing the chassis? Is he using the stock clutch/flywheel/gearing?
T. Thomas is offline   Reply With Quote
Old 01-15-2006, 09:58 AM   #7
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Sounds like an air leak. Is he using the same fuel tank and lines in both cars?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 01-15-2006, 05:09 PM   #8
SSmoked's Avatar
the clutch should be fine, if it works on the other car it would work on the 4tec, except ill let him to to check for rubbage, that sounds possible, and ill pass on the info on the air leak! thanks!
Old 01-15-2006, 05:27 PM   #9
Trader Rating: 15 (100%+)
I don't know of this car but could it be that it has a over drive to the front wheels and he is running the same size wheels front and rear??
THE DOCTOR is offline   Reply With Quote
Old 01-15-2006, 10:52 PM   #10
SSmoked's Avatar
i doubt it, this car comes with same size wheels front and rear. ive never seen a car that doesnt use the same front and rear lol.
Old 01-16-2006, 09:04 AM   #11
The new MTX-4 and the RRR both want you to run smaller front tires.
Old 01-16-2006, 09:12 AM   #12
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I think you guys over looked something! The 4-tech has a P.O.S. Pipe, I would bet it is restricting the flow.............
Paul..................
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-16-2006, 10:39 AM   #13
SSmoked's Avatar
ill pass that on too, thanks, just found out this is a OLD 4tec, over a year old. so its not the nice new 2.5. im not sure what changed between the 2 as far as the car, but if that brings any more ideas we are still trying to figure his car out.
Old 01-16-2006, 05:24 PM   #14
these guys obviously don't see the question lol. How are the wheel hexs held on on the 4tec? Some cars if you over tighten the wheels it will slide the hex up and lock it up. I would pull the motor if it still binds pull the middle belt off and find out where the bind is but check the wheels it might be something stupid like that
Dan D is offline   Reply With Quote
revo 3.3 crack evilflippy1 Electric Off-Road 6 03-29-2007 04:41 AM
Elmo on crack!? XrayFK Chat Lounge 15 12-04-2006 02:08 PM
Most Unique Nut Crack Ever lol (vid) davebuckford Chat Lounge 12 03-10-2006 07:23 AM
Undecided and about to crack up! mumbojumbo Monster Trucks 2 04-16-2004 04:19 PM
