Old 01-14-2006, 09:14 AM   #1
never lift's Avatar
Send a message via AIM to never lift
Default rs4 3 ss chassis on the ground
my rs4 3 ss chassis on the ground . i followed the manual when i built it . but there seems to be no suspension at all the wheel shaft's are tilted up and the chassis is hiting my bench .. this is my fifth kit so i'm not new to it ...
never lift is offline   Reply With Quote
Old 01-14-2006, 10:52 AM   #2
Jye
my kit scrapes the ground alot too, the shocks just suck on this kit. you should be able to get it sitting off the ground though.
Jye is offline   Reply With Quote
Old 01-14-2006, 11:20 AM   #3
never lift's Avatar
i meen it scraps the bench . my pro2 has better clearance ..
Old 01-14-2006, 11:25 AM   #4
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Recheck all shock tower positions. The length of the shock.
Here is the best picture I could find off hpi for how this thing should look.
Hope this helps.
Artificial-I is offline   Reply With Quote
Old 01-14-2006, 11:50 AM   #5
never lift's Avatar
it's mounted like the pic but still on the ground i'll check my shocks . i used 60wt in them ..
Old 01-14-2006, 02:46 PM   #6
FF25510's Avatar
could you post some photo of yours
FF25510 is offline   Reply With Quote
Old 01-14-2006, 04:14 PM   #7
hav_lova's Avatar
The shocks dont look very adjustable why not try some spacers on the shocks
Just playing with bigger toys now...
serpentrc.com.au
hav_lova is offline   Reply With Quote
Old 01-14-2006, 05:55 PM   #8
never lift's Avatar
i tried the spacers and no luck .
Old 01-14-2006, 08:57 PM   #9
never lift's Avatar
the manual says build shocks to 64mm well that's just duckie . but they are not correct they need to 70mm they are now 70mm but i have the biggest spacer in the also . i will need to get the super shock set .. thanks for all the help ..
Old 01-14-2006, 09:44 PM   #10
Send a message via MSN to wei25
i faced this problem too maybe juz add more spacer and adjust the purple thing lower (the part where u clip the shock to the chassis) so that the chassis will not be that low. other wise get a new shock as the stock ones sucks. i'm new to this hobby so is juz my 2cent worth.
wei25 is offline   Reply With Quote
Old 01-15-2006, 01:33 AM   #11
Rapid Roy's Avatar
I'm pretty sure that you have done somthing incorrectly. HPI has sold a zillion of those kits and would have fixed a problem as basic as that. Just recheck the mounting points for the shocks. Did you attach the ball ends in the holes shown in the manual? Is the rear shock tower installed correctly? It should look exactly like the picture posted above when you are finished. Maybe you could post a picture of your car. It might make it easier to figure out what went wrong.
Good luck
Rapid Roy is offline   Reply With Quote
Old 01-15-2006, 11:50 AM   #12
never lift's Avatar
my springs are on upside down ..
Old 01-16-2006, 10:35 AM   #13
5iN
5iN's Avatar
Can you get a pic of the car?
5iN is offline   Reply With Quote
Old 01-16-2006, 12:34 PM   #14
never lift's Avatar
i would need to send it to your e-mail as i can't upload it to here
B44 brand new.Never hit the ground. MikeMalinconico R/C Items: For Sale/Trade 0 08-19-2008 07:44 AM
tc5 never hit the ground lonslo R/C Items: For Sale/Trade 10 09-07-2007 06:32 PM
1/10 Kit - from the ground up CogLioStro Rookie Zone 3 05-16-2007 09:18 AM
Ground Effects XNXIXTXRXOX Nitro On-Road 8 01-05-2007 12:51 PM
ground-round A+++ polesitter61 Buyer/Seller dispute and Feedback discussion forum 0 06-01-2006 10:02 AM
