Setting track width >
Setting track width
Setting track width
Old 01-04-2017, 02:13 AM
Default Setting track width
I'm rather new to 1/8 onroad, how do I set the front and rear track width? Thanks.
N15M0 is offline
Old 01-04-2017, 04:43 AM
Roelof's Avatar
Screw all pivot balls equally to the outside.
Roelof is offline
Old 01-04-2017, 06:32 AM
1/8 IC Fan's Avatar
Trader Rating: 58 (98%+)
also make sure to recheck your camber and toe (f&r) afterwards. As you decrease / increase track width you should readjust the steering rods to maintain your front toe.
Watch Michael Salvens videos, they are helpful;
https://m.youtube.com/watch?v=pjecRkYoT6M
1/8 IC Fan is offline
Old 01-04-2017, 09:21 AM
I watched all the 5 videos but he doesn't seems to be covering the topic on track width.
N15M0 is offline
What do you mean screw all the pivot balls equally ti the outside?
N15M0 is offline
Old 01-04-2017, 10:19 AM
Roelof's Avatar
https://www.teamxray.com/teamxray/sh...p?file_id=3577
page 11
The screws with which you set the camber are also used to set the track width, you only need to screw out both lower and upper screws.
Roelof is offline
