-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   Glow plug (https://www.rctech.net/forum/nitro-road/97258-glow-plug.html)
Quietroit 01-11-2006 05:32 PM
Glow plug
What glow plug is good for 40% nitro fuel
nitrodudes 01-11-2006 05:39 PM
The coldest one.. :) 40% seems like overkill to me.
Chris West 01-11-2006 05:43 PM
i agree that engine gonna have a short life if you use that much nitro :nod:
SSmoked 01-11-2006 05:45 PM
again, what the hell are you using 40% for? back off! lol drop down to like 20%
GFIGUEROA 01-11-2006 05:46 PM
SHIM IT SHIM IT SHIM IT SHIM IT. AND A VERY COLD PLUG! DID I TELL YOU YOU NEED TO SHIM IT? :p :sneaky:
Chris West 01-11-2006 05:47 PM
I use 16% for my 10th
Chris West 01-11-2006 05:48 PM
you must be mixing it yourself, cause what dumb ass fuel company would mix 40%
markallen 01-11-2006 06:02 PM
I have seen 60% at my LHS.It is made for boats.
Mark
wi1dc4rd 01-12-2006 03:11 AM
wow 60% that is high
nitro_racer23 01-12-2006 03:22 AM
Dont use 40%
i have had many engines over the years and the max i have ever used was 20% i do everything from club events to gold cost challanges and some state titles and most of the guys there use 16% so if you want your engine to last long term drop the nitro down to 20% or 15% and like MANINTHEMUGEN said shim it.
THE DOCTOR 01-12-2006 04:33 AM
You don't need to shim it if you run 20% or lower.
Chris West 01-12-2006 12:52 PM
yeah no need to shim it on 20% or lower you will just make it slower
Francis M. 01-12-2006 01:34 PM
40% percent is pretty high but I see a lot of guys using it. If you use odonell plugs go with #97 or #99. for nova i would use #7tf or #8tf and its been posted before but you will need to shim the engine.
Artificial-I 01-12-2006 07:02 PM
Yeah double the amount of shims at least and go polar bear toenail cold plug like. Your motor is also going to loose reliability.
quickie 01-12-2006 07:49 PM
Go to www.rbproducts.com and scroll down the left side to "which glow plugs to use?" and look at the ambient temps vs. nitro, etc and see which to use.
Good luck
Content © 2001-2011 RCTech.net
